Configurations - Features Suppressed
I have a part with multiple configurations, and when I add a new feature to one config, it becomes a suppressed feature in all of the other configs.
If I edit a feature or sketch dimensions, I can select which config the change affects, but I can't find a similar option when creating new features.
Depeding on the model, sometimes I would like it suppressed in the other configs, but if it is a feature I want shared with all configs, I would like it to be unsuppressed in all of them.
If I want it unsuppressed in all configs, I find myself going into each config and unsuppressing each added feature. This is time consuming and leaves the potential for missing some.
Is there a way to specify which configs a new feature will be suppressed/unsuppressed in? Or is there a global setting that I could change on a case-by-case basis?
Lou
RE: Configurations - Features Suppressed
RMB on the part->properties. There's an option for suppression. You can then select what configs you want it suppressed in.
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Also, in the config property manager there is an option regarding suppression of new parts. It's under Advanced Options when you create a new config, or if you RMB->properties on a current config.
Jeff Mirisola, CSWP
Jeff,
 Your 2nd answer is exactly what I was looking for. That will work out very well for me.
Lou
In the FM, select the feature and RMB edit feature.  Then, depending on the type of feature, there will be a "configurations" box that might need expanded.  There you will have the same configuration control that you have for dimensions (this/all/specify).
