Pipeline Modelling using Hysys
Please can somebody give me some guide on how to model a pipeline, 11472m long using Hysys. I would like to have the pipeline profile as part of the result.
RE: Pipeline Modelling using Hysys
Hysys appears to be good for short pipe work though.
http://virtualpipeline.spaces.msn.com
Thanks very much for the comments.
However, by installing a pipe segment and defining the inputs i.e increments, is it not possible to have the pi[peline profile to cover the entire length.
Also, what maximum pipe length can be comfortably handled by Hysys?
I have made a macro in excel that will arrange the values that i need in rows and collumns. I have actually made the macro so that i can put many result files in a specific directory - and excel will then open all files and process them in one operation.
Best regards
Morten
Yes as MortenA says, it is possible, but you can see it is not a very nice solution.
HySYS is the premier process model. Basically it is great where pipe is just long enough to get from process to process.
David
Best regards
Morten
