LVL header/keybeam question
I have a 14' long header situation with bearing at 3 points (the ends and the midpoint at 7'). I am using keybeam software to size this LVL header. When I put my loading in the beam size I have selected fails, the bending moment and shear values are well within capacity, only 24%, but it fails the beam based upon "maximum reaction". I am not sure I agree with this mode of failure, curious your guys' thoughts. As long as I have proper bearing area under these bearing points shouldn't the beam be fine? I do understand that there is a horizontal shear associated with a vertical load but the software indicates I'm only at 24% of allowable shear. If I break this header up into 2, 7' headers everything is fine in the software regarding maximum reaction, but I know the builder will just put one long header in no matter what I specify. I do understand that a 14' vs. 2, 7' headers does indeed induce additional shear stress at the mid point bearing section but I'm just not convinced this beam will fail at that point. Any thoughts are appreciated..
RE: LVL header/keybeam question
