5/16-18 Button Head Socket w/Nylon Pellet
I am trying to source a 5/16-18x1 button head socket screw that is self-locking.  We have tried the hardware with the applied patch of thread-locking compound, but we have twisted the heads off a few during disassembly.  I am wondering if anyone has a source for this size hardware that has a nylon pellet for the locking feature?  I know I have seen them on set screws, but do not know if they exist on this size hardware as a standard components.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: 5/16-18 Button Head Socket w/Nylon Pellet
www.mcmaster.com
McMaster-Carr part  92360A425
they have stainless also.
Badservo, these are the ones that have the applied patch, I am looking for a inserted nylon pellet instead.  Thanks though.
Mango,
I would like to give you some unsolicited advice.  Thermoplastic polymer patches are practically worthless.  If you can't reliably retain preload in your joint, use thread adhesive.  There are many versions, from reuseable to never get it off.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Corypad, I understand the advice you are giving me, and appreciate it.  The self-locking attribute is a customer driven requirement.
I have found a source, http://www.longlok.com
So you are considering the Tek-Lok product (pellet), not the Poly-Lok product (patch)?
Either way, I weep for you...
Take a look at
http://www.accuratescrew.com/Optional-Product-Features.aspx
I think I've got fasteners from them before, but not with the patch or insert.
I just did a search for MIL-F-18240 and they came up.
My last place used the patch type to MIL-F-18240 (not from this supplier) on setscrews on aircraft stores.
Tried combining MIL-F-18240 with button head and didn't get much.
http://www.google.com/search?hl=en&q=MIL-F-18240+button+head
This one may be worth looking at.
http://www.qualifiedfasteners.com/card.html
KENAT, probably the least qualified checker you'll ever meet...
You could try Nylok's "Blue Pellet".
www.nylok.com/products_bluepatch.htm
About ten years ago I did some work in Anaheim facility and picked up a handfull of stuff that should work...if they are still there.
Rod
