Can I change the Drawing Units using VBA
I have a routine that asks the user to select 2 points. I need to have the precision to 4 decimals but if they have the drawing units set to 2 decimals I don't get accurate data. How can I change the drawing units using VBA?
RE: Can I change the Drawing Units using VBA
Using AutoCAD Mechanical 2006, UGNX4, XPsp2, MSOffice 2K3
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
