Restriction Orifice for Stainless Steel Pipes
A quick question: Can restriction orifices be mounted on stub-end pipe joints with SO flanges or it is required/better to use welding neck flanges?
RE: Restriction Orifice for Stainless Steel Pipes
The specifications that I have for general flanged connection are:
1) Sch 40S A-312 SS pipe, stub ends, A-105 class 900# lap joint flanges.
2) Sch 10S A-312 SS pipe, stub ends, A-105 class 150# lap joint flanges.
These are for various process services.
I was wondering if it is good practice to install restriction orifices with this lap joint flanges or it is better to use welding neck flanges instead.
