Truss plate sizing design for prefab trusses
Has anyone else wondered how truss plates are tested and rated for certain loads (say 150p/si of plate)? I get the feeling that lab tests are absolutely straight pulls on the plate, yet the plates at actual joints are pulled in several directions at once. How do truss engineers justify slapping a 6x10 heel plate on a joint between a 2x8 topchord and a 2x4 bottom chord? The plate has to work as a cantilever off the 2x4 and has to rotate in order to transfer tension loads. Yes - I know that factors are applied for perpendicular and parallel stress - but the forces are offset, yielding a moment force on the teeth. Does the truss supplier software take these factors into consideration when they size a plate?
RE: Truss plate sizing design for prefab trusses
OK - you've got some accurate modeling program. But my basic question was how do you convert all those moments and forces into a 6x10 plate?
A final question arises when the fabricator tries to accurately position this 6x10 plate. What is the methodology for locating this plate for most efficient load transfer to all those finite teeth elements?
I don't think Chapter 5 gets into determining moment capacities of the plates, only how to test the specimens and what minimum tests are required. They show straight pull tests and also require 6 tests where the plates are skewed at varying angles across a shear plane. I believe the moment capacities are determined by the manufacturers and used proprietarily (if that's a word).
We use self calibrating laser jigs to set the plates. They project the outline of the plate on to the truss. They are tied into our software and are very accurate.
Another question: I can imagine the laser helps with accurate placement on the top side of the truss, but what about the back side?
The back side of the truss requires good judgement on the truss builders part. Larger plates aren't a problem. The smaller plates seem to be the ones that are harder to locate on the back side.
Based on replies I have read: it seems that tests on plates do not mimic real-time forces on plates or time-dependent creep and deterioration of holding strength. The 'black box' proprietary solutions for plate design mentioned should be transparent to outside engineers.
It is surprising to me that code authorities even allow plate manufacturers (who have a vested interest in minimizing plate sizes to reduce costs) to claim that gang-nail plate behavior is 'proprietary'. It's one thing to have a different tooth design and protect it by patent, and quite another to claim that shear, tension and moment forces can not be revealed because they are a 'secret'.
And I'm not referring to secondary moment forces; only those caused by forces not acting on the same line of action.
Is anyone aware of any load tests performed on full-scale prefab trusses? It would really seem like the time has come to compare actual truss failure loads with 'proprietary' black box solutions.
Why don't you call Mitek or Alpine and talk to their engineers, I don't think they're hiding from you.
ALso, I think the SBC just built a facility to test trusses full scale.
http
In regards to the subject of vested interest on the part of a material supplier, if you consider that various fabricators will try to submit lower bids in order to get the job you will understand the reason for using smaller plates once you do get the job.
I still have no understanding of what *methodology is used by 'black box' decisions to use a 6x10 vs a 4x14 at a heel joint. Anyone?
*or should I call it faith-based
The methodology used by 'black box' decisions is no secret. It is simple matrix analysis. The proprietary part of the programs are how they choose to model the various configurations. For example the location of the nodes at a pitch break may be slightly different from one software to the next.
The decision to use a 6x10 vs. a 4x14 is fairly complicated and would take too long to describe here. If you are interested in learning, I would suggest contacting one of the plate manufacturers and talking with them to see if they have any information they could give you. Good luck.
Until then, faith based may be your best bet.
