hydraulic cylinder internal threads
hello all - small question here - i have a design problem that i am not sure of the correct formula to use for the stripping of threads - i have a gland threaded into the body of a hydraulic cylinder that has a burst presure of 9000 p.s.i. - the tube is made of a572 steel & the threaded gland out of 80-60-05 ductile iron - i have used the thread stripping formula out of machinery handbook & found what the length of engagement should be but am not sure how the 9000 pounds force plays into the formula - any info would be appreciated - thank you
RE: hydraulic cylinder internal threads
A less conservative approach would use the same area, but the actual maximum system pressure times an appropriate safety factor, not the burst pressure of the cylinder tubing.
Mike Halloran
Pembroke Pines, FL, USA
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
