anchors set in epoxy adhesive
This question relates to rebar or threaded anchor dowels set into epoxy adhesive with certain embedment into REINFORCED concrete members.
Is it acceptable to ignore the effect of anchor SPACING and/or EDGE distance on their allowable bond/concrete strength, due to the fact that reinforcing rebars intersect the assumed failure cone surface of concrete?
Thank you.
Thank you.
RE: anchors set in epoxy adhesive
How can you get credit - improving the anchor capacity - for the fact that reinforcing exist, knowing that the load capacity of such anchor is based on plain "unreinforced" concrete test setup?
Thank you.
Your statment is not clear as to why, how and by what amount reinforcing can help when the reinforcing intersect a tensile/shear failure cone, or in other word the concrete failure cone.
epoxy anchors can fail in one of the following three modes of failures:
1. Steel failure
2. bond failure
3. concrete failure
I am intrested in the concrete failure surface that takes the shape of a cone in most cases.
Now, since reinforcing does intersect the concrete failure cone, shouldn't the concrete failure capacity be higher than the one that has no reinforcing intersecting the concrete failure cone?
secondly, what is the difference between the concrete failure cone of a wedge anchor and that of an epoxy anchor?
and finally i am interested to know why/how reinforcing can help the wedge type anchor? by what amount?
Thank you.
This is more than a simple statement in that the code resumes usually what recommendable and what not.
Basically and till I see a reasonable and general treaty on anchors to whatever (which surely will be some tomes) I think I have to agree with the code stance, since except quite precise clarification of what kind of anchors are referred to and what relative disposition of the reinforcement there is, designers would misinterpret the new allowance, as in fact I think is the case in general with the design of anchors at the present, for which my common sense and experience about what the materials and structures stand indicates bigger anchors than those allowed should be specified.
The enormous variety of anchor systems, influencing variably the surrounding concrete and for some proportions and closenesses having bursting and slippage modes of failure neither help.
In any case, you can still come to an strut and tie mechanism to guess how the re-bar will influence a simple case of tension, it would be something rigid footing-like...for the shear case a pair may be thought acting and then bencing of both the rod and an assumption of bending or sutrut and tie again be made to take the forces in the pair...then interaction you can use some of the standing formulas...and then better you check what you are doing is certified be safe 95% of the test times, for this may have rational basis but lacks both correlation to any tests and code support.
The above information was derived from the paper entitled, "Building Codes and Anchoring to Concrete" by Richard Wollmershauser. The paper can be found on the Hilti web site.
