Flap Valves/ Reverse Flow
How do you model a underground storage system with multiple chambers that has a flap valve to allow flow in one direction only? The model requires the pond and reach to use storaqe and routing to use dynanic-stor-ind. Thanks for your help!
Mark
Mark
RE: Flap Valves/ Reverse Flow
In rare cases were reversing flows are required, a reverse outlet device is used. See www.hydrocad.net/simroute.htm
