Need help with Abaqus/CAE modeling: 4pt bending and twisting of plate
I am modeling a 3D bone plate and I am having trouble setting up the conditions.
the diagram looks like this eg.
_________________
( O O O O O O )
(_________________)
sort of. rectangular, 6 holes
symmetrical about the long axis and the axis perpendicular to that
First I want to model it in bending.
I am setting the mid axis as fixed and only modeling a quarter of the plate for simplification reasons.
I have symmetry about x and y and y axis fixed.
I want to simulate a 4pt bending test but I am not sure how to get the loads correct. I cannot put a load on the furthest edge from the mid axis.
I am not sure how to do this in abacus. Any ideas?
Also, how would I be able to put screw loads along the hole axis? Cannot figure this out
Next I want to be able to model it in torsion.
for this I want to use the full plate. Fix one end of it, have the screw pressures in all 6 holes. But I need to fix 3 of the holes on one end and model it across the mid point.
How can I have a screw load along an edge and not a surface?
Can I fix three holes on one end and keep the other three free? Especially, with a load in all 6 screws?
Any help or advice would be greatful. Thanks much and cheers,
Jerry
_________________
( O O O O O O )
(_________________)
Jerry
