Set Initial conditions in Aqus/CAE
I write the subroutine SDVINI, it requires the Initial Conditions option. Now, I work Abaqus/CAE, I dont know how to set initial condition. Help me!
RE: Set Initial conditions in Aqus/CAE
Use keyword editor.
CAE->Main Menu->Model->Edit Keywords
Dear XERF!
I read the your answers in this forum to get state variables. I copied the method to receive the coordinates by SDVINI then to give them to HETVAL. I have inserted the "*INITIAL CONDITIONS, TYPE=SOLUTION, USER" into the Model, but I cant run the Subroutine SDVINI. I want get the coordinates of nodes as well node number to transfer to Subrountine HETVAL. I cant get the Coords(3). What is wrong?
My Subroutines:
    SUBROUTINE SDVINI(STATEV, COORDS, NSTATV, NCRDS, NOEL, NPT,
    1    LAYER, KSPT)
C
    INCLUDE 'ABA_PARAM.INC'
C
    CHARACTER*80 CMNAME
    DIMENSION STATEV(NSTATV), COORDS(NCRDS)
C
    STATEV(1)=NOEL
    STATEV(2)=NPT
    STATEV(3)=COORDS(1)
    STATEV(4)=COORDS(2)
    STATEV(5)=COORDS(3)
    RETURN
    END
    SUBROUTINE HETVAL(CMNAME, TEMP, TIME, DTIME, STATEV, FLUX,
    1 PREDEF, DPRED)
C
C
    DIMENSION COORDS(3)
    INTEGER NPT, NOEL, OpenStatus
    REAL A
    CHARACTER*80 CMNAME
C
    DIMENSION TEMP(2), STATEV(5), PREDEF(*), TIME(*), FLUX(2),
    1 DPRED(*)
    COORDS(1) = STATEV(3)
    COORDS(2) = STATEV(4)
    COORDS(3) = STATEV(5)
    IF (COORDS(1)>10) FLUX(1)=1000
    RETURN
    END
I think It is good, but I cant take the coord(3) to analysis. Can U help me?
1. SDVINI and HETVAL are called for the each integration point and not for nodes.
2. The coordinates represents the coordinates of the Gauss integration points and not of the nodes.
3. Is your model 3D ??
4. Did you define DEPVAR (number of state variables) in your model (or input file)?
5. Try use STATEV(*) instead of STATEV(5)
Thank XERF, I forgot to set DEPVAR. Now, I got the good result. Thank You very much.
