Rib sectioning question
Thinking back to SW2005, does anyone know of a method that will display a section of a rib in old school drafting methods where the rib is sectioned and the surrounding material isn't or vice-versa?
Unfortunately, answers pertaining to newer versions will not be of assistance.
Thanks in advance.
Thanks in advance.
Christopher Zona - Product Designer
Concord, Ontario
RE: Rib sectioning question
Create a configuration of the part. Create a cut that sections the rib. In your drawing, you can select that 'sectioned' area to be hatched. Maybe not the cleanest way to do it, but...
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
I'm thinking of just using a break-away view and stopping short of the rib.
Concord, Ontario
