Smith Prediction
Smith Prediction
Can anybody point me to information on "Smith Prediction" I'm told that it is a variation on 3 term control that can look forward to what will be happening in the future.
I can find many articles that refer to this but not a publication that gives me the basic information.
As ever I need it yesterday/
RE: Smith Prediction
Sometimes I only open my mouth to swap feet...
Tried that, I found some info on the isa.org page but this is mainley papers abbout it's application not the basics.
Mehdi Delrobaei
http:/
Dagur
http://www
and look at the slide show. There is a slide that is titled control structure. One can see the control output is sent to both the plant and the model G0(s). The model for G0(s) is the model for P(s) WITH OUT THE DELAY exp(-s*T). The PV calculated from the model is then used for feed back and is used for correcting errors in the model. The output from the model is delay by the same exp(-s*T) as the plant dead time T. This delayed PV is subtracted from the current plant value and this difference is added to the feedback. Hopefully there isn't much difference between the model PV with dead time applied and the plant PV. This means the model is good and the controller is mostly using the model feedback as if there is no dead time.
