Dynamic Analysis: Modal superpos. or Direct Int.
In the field I am in (structural) mode superposition is commonly used to perform dynamic analyzes. Is this a default analysis method also for other fields, e.g. automotive, mechanical,...?
Of course, direct integration is more accurate but is the accuracy of a modal superposition generally sufficient?
Andreas
Andreas
RE: Dynamic Analysis: Modal superpos. or Direct Int.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
