Liquid distributor irrigration quality test
Dear sirs,
As part of a distillation column order I have asked for water tests on the proposed vendor distibutors.
In kisters book he quotes a Moore and Rukovena quality index for liquid distribors. Do column vendors normally measures there distributors v's this test.
What are common results for good distribors... v packing types..
Should the packing vendor advise on this or should we state we require..
I've see a vendor perform a test (i was at there shop for another reason).. but i dont know how they measure it..
RE: Liquid distributor irrigration quality test
Each of the liquid distributors must be subject to a quality test with water, witnessed in shop by the customer or his representative.
Points to be checked are: Quality manufacture, tightness, distribution accuracy and throughput.
For more information go to
h
htt
http://www.montz.de/sites/products/liquid.html
luismarques
Thanks for you post..
THerefore in terms of QA for a shop test.
Validate the following is sensible
Distributor meets the following:
> Quoted rate drip points per meter. (through the flow range)
> Does not overflow at design rates (Adjusted for density)
> meets drip rate an min flow.
Would you specify a moores distribution number or would you ask the manufacturer to advise what is required for his packing to meet our NTS requirements ?
