HVAC DIMENSIONS
HVAC DIMENSIONS
HVAC DIMENSIONS
I need dimensions for HVAC Residential units so that I can complete my house plans. 2 ton electric(2 units-1 upstairs, 1 downstairs)
RE: HVAC DIMENSIONS
Check the major manufacturers, Carrier, Trane, etc, they have info on their websites.  The size will vary with manufacturer and unit selected.
RE: HVAC DIMENSIONS
22" wide by 24" deep by 48" high should be close enough for some drawings. Most of the residential equipment is designed to fit between 24" o/c trusses.
Take the "V" out of HVAC and you are left with a HAC(k) job.
