Starting Solidworks
Starting Solidworks
Whenever I start 2007 Solidworks I get the following
"Failed to update the system registry. Please try using
REGEDIT"
After typing in RUN <REGEDIT> Solidworks opens without any problem
Anybody had this before.
REGEDIT"
RE: Starting Solidworks
Reboot your pc. If it continues with the same message, try doing a repair of SW.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
"If it's not broke, Don't fix it!"
Taken from h
Thanks for the tip. It worked but not exactly. Now I do not need to run regedit, I can just click OK and it will load itself. It's annoying but OK. May be there is something else I need to change.
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
