ASME Y14.5-1994 Assumed 90 degree angle on the print
Under the ASME Y14.5-1994 - Is there anything relating the appearance of all right angles as 90 degrees. I have been told that you must assume that all right angles are 90 degrees.
1. Is it true under the ASME standard I posted?
2. Furthermore, do you assume the title block tolerance on that 90 degree angle??
Thanks in advance
Thanks in advance
RE: ASME Y14.5-1994 Assumed 90 degree angle on the print
KENAT, probably the least qualified checker you'll ever meet...
Powerhound
Production Supervisor
Inventor 11
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
