Paddle Blinds, Spectacle Flanges, Bleed Rings & Spectacle Blinds
Hello All,
This might be too naive a question to put before you all, even then, could anyone mind writing down few lines about the following ( both functional & physics point of view & some standards (or) references for design of these items)
a) PADDLE BLINDS
b) SPECTACLE BLINDS
c) BLEED RINGS
d) SPECTACLE FLANGES
Appreciate your time.
a) PADDLE BLINDS
b) SPECTACLE BLINDS
c) BLEED RINGS
RE: Paddle Blinds, Spectacle Flanges, Bleed Rings & Spectacle Blinds
Specticle blinds are blind flanges, only mated with a skillet having an opening equal to the ID of the line. The handle between to soild and the "hollow" skillet is shared, hence it looks like a pair of eye glasses, one is solid and the other has an opening like a glass frame. The same equation works. These are installed where they are in use all the time where the process must be 100% isolated (no leaking valves allowed). Make sure your piping designer knows the thickness so you can leave space for in in the line.
Bleed rings are like the hollow side of the specticle blind. On the hollowed out plte, a hole has been tapped from the inside to the outside. so the user can thread in a nipple and valve. This is essentially a tap into the process. If placed between the flange on a valve and the flange on a reflief valve, one could closse the valve and bleed the pressure off between it and the relief valve.
Specticle flanges, would be two ordinary flanges with enough gap between them to accept the specticle blind of the properly designed thickness between them.
