A CAD problem in FE software ABAQUS
Hi
here is the problem:
I 'm developing an script(python).In part of that script,I should generate several lines by connecting node of current step of a forming process and previous step and intersect it with an arbitrary surface which is imported from a CAD software.The intersection points of these lines with CAD surface is what i need for next steps of process.Any body has any idea how it should be done????Pls HELP!THX
RE: A CAD problem in FE software ABAQUS
TTFN
corus
thank you for your comment
But The problem is that the Abaqus has no feature for intersection of line-surface in fact the cad module of ABAQUS is so weak do perform this intersection!Am i not right?
Dariush
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I actualy found the solution to my question.So I dont need to go through maths behind the intersection.thank you for your comment anyway.and i m ready to explain the way to do such an intersection in ABAQUS if any one is willing to hear.
Dariush
