Allowable pressure rating for 2" x 3/4" reducing fitting?
Let me first explain the scenario...
Currently, we do Cavern Integrity Tests on underground oil storage caverns periodically. When doing so, nitrogen is purged from the wellhead into a frac tank. Connected to the wellhead is a 2" x 3/4" reducing fitting with internal threads which is immediately connected to a 2" hammer-type coupling and then that is connected to 2" hose into the frac tank.
My question is...I know that the hammer-type coupling is rated at 2000psi, however, since there is a weak part in the system (the location at which the reducing fitting is threaded to the wellhead), will that location as well be rated at 2000psi? The overall system must be rated for at least 2000psi. Help please!
RE: Allowable pressure rating for 2" x 3/4" reducing fitting?
2" x 3/4" S/80 A/SA234 WPBN W8297 GT
Is there any indication from the above information that may answer my question?
Good Luck!
