Insulation for double wall vent pipe
I have a boiler exhaust vent that I am trying to figure out the minimum required insulation thickness for. The vent is a stainless steel double wall pipe with a 1" air gap.
I am trying to select the fiberglass insulation thickness to keep the surface temperature below 130 degrees F for personnel safety. However, the air gap between the pipe is trowing me off. The 3E Plus program does not allow you to model a double wall pipe. Can anyone provide some insight?
Thanks!
Thanks!
RE: Insulation for double wall vent pipe
