Fuel Gas Temperature to GTG
Currently our fuel gas skid got heater to ensure/control fuel gas temp entering GTG combustor at 42 C. If the heater fail/trip & let say the FG temp reduces below 30 C, what is the impact to GTG? Was told the GTG will trip? What the normal criteria of FG temp?
ppm
ppm
RE: Fuel Gas Temperature to GTG
We heat our fuel to 150 F.
Adding heat or raising the temperature of the fuel gas will slightly increase the appeant efficiency of the GT. I say appearant because if you burn gas to make the fuel gas warming, you will lose efficency overall.
The event of the Fuel Gas Heater trip/fail is not necessarily detrimental to the GT if only occurring a few times. If the unit is setup correctly and depending on the unit model, for example a GE 7/ 9FA+e would simply perform a runback to a minimal pre-selected mode and load. However there are users out there that, to save money and not necessarily affect their trip counters for maintenance factors, use this method of shutting off the Fuel gas heaters to respond quickly to dispatch orders giving them the ability to shut the unit down quickly. This method does save time and fuel verses a normally regulated shutdown however they do so at the cost of Combustion Hardware and reliability issues as this practice causes higher than normal thermal stresses in hardware. Many operators assume that the OEM’s do not know that this is becoming a common practice and frequently attempt to blame reliability issues and hardware damage on the OEM’s under the guise of warranty claims. However I can assure you that the OEM’s are aware of this practice and may quickly dismiss warranty claims, as this practice is easy to spot in the control data.
Romefu12
The low fuel temperature alarm and runback is a common practice but most units have only an alarm as the main issue is to avoid slugs of liquid entering the gas fuel and combustion systems - so while the liquid level in the scrubber is below trip level the unit will run safely.
42C is not really heated fuel, it is just to avoid condensations... some units run with 185C fuel
saludos.
a.
