How do you read mAh?
I know mAh stands for milliamps per hour but does that mean what the battery can deliver as the max for any time frame? In other words I'm powering a circiut that demands 500mA and the battey is rated for 500mAh guaranteed can I expect that battery still have enough life for reasonable application?
Or, does mAh represent the cumlumative current draw of the battery in an hour? In other words (using same example above) will the current only equal to about 1.4mA per sec?
Thanks in advanced for responding
RE: How do you read mAh?
... theoretically.
Batteries are rated for capacity at just one current, usually a low one. The capacity is reported as the product of that current and that time. I.e., it's not mA per hour, it's mA times hours.
You probably won't get 500mA out of it for an hour.
Mike Halloran
Pembroke Pines, FL, USA
Generally batteries are rated over 10 or 20 hours.
Call C/20 for 'capacity'(the Ahrs)
Typically your 500mAhr battery..
Will provide 500mAhr of energy if you DO NOT draw more than 500mAhr/20hr = 25mA.
Keith Cress
I think MarkHalloran nailed it right on the nose. It s the same in car batteries. Only this time its not milliamps but amps. Does this help?
capuchi
The designation mAh is read "milliamperes-hours", if multiplied by voltage would give energy.
In your case, 500 mAh would be the equivalent of 500*3600 => 1800000 mAs = 1800 As = 1.8 kAs.
For that particular battery, if it is a 12 V battery, the energy would be 500 mAh x 12 V = 6000 mAVh = 21600000 Ws = 21.6 MJ (Mega-Joule).
The representation for " milliamperes per hour" would be mA/h.
I interpretted the units wrong. Makes sense now. It should be like when the electric comapny reads your meter in KW*hours. Which is how much power hourly is being delivered to your home.
But because a rated for 500mA is not continous (by that I mean as the battery provides power to the circuit its voltage gradually decreases). So the battery has a battery life of 1-hour (much likey less) at 500mA.
But to extend the life you deliver less current as "itsmoked" mentioned.
Kinda a side question:
Why are power supplies rated in VA and not just Watts?
Just about none of the supplies I have/use are rated in VA. VA generally is applied to AC type supplies.
Keith Cress
When batteries are tested, they vary the load resistance to keep the current steady. Most real world loads don't behave this way. Also, the rating is non-linear. You cannot extrapolate the 10 hr rating to find the 1 hr rating, for example. You will need the curves from the manufacturer for this.
In the real world, distribution systems are based on VA, KVA or MVA. The current and losses in distribution systems are dependent on Volt-Amps, not Watts.
respectfully
