dxf COMPATIBILITY Solidworks 2007
Hi, we are using Solidworks to create dxf's that our suppliers use for CNC procedures.  Problem we've been having with 2007 is some of our suppliers are claiming when they open our files 80% of the lines are doubled up (2 on top of each other) & some radius fillets are missing.  Has anyone experienced similar?  We are trying to figure out if the problem is at our end or theirs.
Thanks.
RE: dxf COMPATIBILITY Solidworks 2007
This is very common with any dxf translation.
Try creating you dxf files, then do a quality check with DWG Editor.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
I had the same type of problem here. What I did was change the setting to write out the DXF as Release 12 and everything worked.
Ken
Make sure that the drawing view used for the DXF is set to "Hiden Lines Removed" or it will show the other side and result in doubling up of most lines, but you probably will not notice it until your supplier tries to use it. Chamfers and centre marks can be annoying for them too!
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
