Catia Standards
Catia Standards
Catia Standards
Can anyone tell me how to change the standard of Text Properties and Default Style? I ran Catia in Admin mode but I do not know where can I change it. I was looking for it in Category - Drafting - Standard - ANSI - Styles but i did not find it.
Thanks in advance.
Best Regards
Santa
RE: Catia Standards
http://www.catiacommunity.com/feature_full.php?cpfeatureid=16924
I used this to create my own set of standards and preferences so that it was set up the way I like it. Once you are in Admin mode you can modify all the settings under Tools / Standards , then category - Drafting and you will see the current Standard on the right - such as ANSI.xml. Modify all the settings to what you want them to be and then "Save As New" and give it your unique name.
The preferred font is located under "Styles" - make sure you type out the name exactly as it appears in the font drop down menu - such as "Arial (True Type)".
