Problem with multiple sheet formats
I have a drawing using a standard sheet format for my company. When I add a new sheet and change the format of the 2nd sheet, it will no longer allow me to save, coming up with some unknown error. If I leave the 2nd sheet the same format, it saves just fine. If I make a new drawing with the format I want on the 2nd sheet, it saves just fine. The problem only occurs when I combine two sheets with different formats in one drawing. Has anyone had this problem, or know how to fix it?
RE: Problem with multiple sheet formats
I have no problem combining different sheet formats...
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
I'm doing what I always do. I right click on the tab at the bottom, and click add sheet. Then the dialog box comes up asking what template to use, and I click on a different one (D size continued) instead of the standard D size template with title block etc. If I keep the standard one, it works just fine. If I click D continued, C, A, B, etc. (basically anything but what the first sheet is) it changes, but won't let me save, autosave, recover, etc.
Also, it lets me save in any format but SLDDRW. I can save to dxf, dwg, pdf, etc, but not the working format.
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
Jeff Mirisola, CSWP
