Dimensions-Extension Line Breaks
Good Morning,
I'm adding GD&T features to dimension extension lines and thought it would break automatically around the feature control frames of the GD&T blocks. Is there a setting in the options area? Right now I have the extension lines running through the frames.
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
Intel 2 Duo Core, 2GB RAM
nVida Quadro FX 3450 512 MB
RE: Dimensions-Extension Line Breaks
I don't 100% understand. How is it running through the frame if it's attached to the dim ext line?
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
I have other dimensions in that view.
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
I'm unable to do it. I look through all the settings. Looks like a ER.
Chris
AutoCAD 06
Colin Fitzpatrick
Jeff Mirisola, CSWP
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
I remember I've always had to move the FCF's around so that the lines do not pass thru. I don't remember seeing a newer version that has changed it.
Chris
AutoCAD 06
Colin Fitzpatrick
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
I submitted and ER for this on Sunday.
Colin Fitzpatrick
