Vacuum Cleaner Attachment Design
I need a little help designing a vacuum cleaner attachment design. This is for a engineering class project. What we are doing is hacking up a Black and decker 4.8 Volt dustbuster to use as our vacuum source. I don't have any other info on the Dustbuster, but what I need to do is design an attachment for it. The intake of the attachment will be 11 inches wide by .5 inches thick. My question is what size should I make the orifice to the dustbuster so I will get a decent "sucking" power. Will this even work? Any help is appreciated, and please, although I would understand a bunch of technical mumbo jumbo, please keep it simple if you can. This is not the basis of the project, it is more of an add on to it.
Jason
Jason
RE: Vacuum Cleaner Attachment Design
You say ".5 thick". Is this a material thickness or an opening width?
Is the "working orifice" considered the side that "picks up the dirt" or the side that exits to the "catch bin".
Something to consider is that the suction power you need. If you just look at the velocities you'll get an idea of your suction. By changing the cross section, you'll be seeing different velocities. The inlet to the pump might be one area, but the vacuum's pickup point might be smaller in area. The reason is that it would be like focusing the energy to one point. If you distribute this sucking force over a larger area, you'll not have enough suction to even lift sugar off of a table.
I would look to the orginal design and try to determine what the manufacturer was shooting for.
Also, keep in mind that the longer the duct work, the rougher the walls are, the smaller the ducts are the more losses you will see.
Try to give some info about what the project is shooting for and advice will usually be more tailored to something that can help.
fan and | | / \
filter |catch | | / \
| bin | | / \
|_| /________________\
Intake Intake
Orifice Orifice
SIDE VIEW FRONT VIEW
I'm fairly sure that you will not be able to suck air quickly enough through an orifice that large (11 inches by 0.5 inches) to pick up anything heavier than (perhaps) confetti. Look at the orifice at the business end of your dustbuster as it came from the store. Anything much larger than that and the performance will drop right off.
Howard
