vacuum tight welding connection
For our application (a vacuum tight tank) we need to have a welding connection with a very high gas leaking tightness. What kind of welding technology is suitable for high vacuum tightness? Our requirement is a leaking tightness below 150 * 10-9 mbar * dm3 / s (for air) for a 10 dm3 volume tank. The length of the total weld is approximately 2 meter (the form of the tank is very slim). What kind of gas tightness is possible for welding connection for industrial applications?
RE: vacuum tight welding connection
All high vacuum equipment use welding.
What metals are you welding? How thick?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
