inverted siphon
inverted siphon
inverted siphon
We are designing a storm drain which will cross the TransCanada Pipeline right-of-way and are considering an inverted siphon under the existing natural gas transmission lines to avoid a costly relocation.  There is some concern regarding possible freezing of the siphon. Anybody with experience and/or know a solution to prevent the freezing?
RE: inverted siphon
If the storm drain and/or the siphon freezes will not the surface streams feeding them also freeze?  What are the consequences of that? What is the depth of frost penetration in your area ?  What are the annual surface temperature variations at your altitude ?
good luck
RE: inverted siphon
Is there a constant flow into the Siphon?
1- Place the siphon sufficiently deep to prevent freezing.
2- Make sure you size your siphon pipe is smaller than the   main trunk to promote pressure flow and higher velocities.
3- Other than that you can use a DIP in a casing and connect defrosting wires to the pipes.
RE: inverted siphon
The project is in southern Saskatchewan
RE: inverted siphon
Provide catch basins at one or both ends of the siphon and have a plan to do regular cleaning of the basins as well as the pipe.
