Is is possible???
Is is possible???
I have a very complex 3 D part. Is is possible to project it on a surface to get sketch in a any plane and then create a sketch of say 1 mm offset from the original part.
I basically want to trim the part by 1 mm.
thanks
thanks
RE: Is is possible???
you can select all faces of the solide by searching (CTRL + F) face then select the thickness in PartDesing
