Suggestions to Ratchet Two Sides
I'm designing a ratchet handle with gears to rotate something 90 degrees in either direction, but I want a safety in the form of a ratchet.
I've found two ways to have a two-sided ratchet here:
http://books.google.com/books?id=T-kgAAAAMAAJ&pg=PA135&dq=%22when+the+arm+swings+in+the+opposite+direction%22
Namely, C and D, but I can't find a vendor that sells them.  I might have to design and machine type C.
Are there other options if I want a method to allow ratcheting in either direction, or are there vendors that sell these pawls?
