ANSI spline call out
Hi, i was reading the following thread,
http://www.eng-tips.com/viewthread.cfm?qid=93789
and it seemed to be along the same lines as what i was looking for, but unfortunately it is closed. I am trying to figure out the correct way to call out a spline in a drawing. my current method looks something like this
23 TOOTH 8/16 DP 30ยบ PA
FILLET ROOT SIDE FIT
CLASS 6
ANSI B 92.1-1970
The machine shop i was using to create this said that my call out didnt have all the required information. Is this the proper form? Am I missing something? Any help would be greatly appreciated!
CLASS 6
ANSI B 92.1-1970
RE: ANSI spline call out
I'm surprised they didn't tell you what information was missing.
Good luck.
Internal Involute Spline Data:
Flat Root Side Fit
-Numbrt of Teeth
-Pitch
-Pressure Angle
-Base Diameter (REF)
-Pitch Diameter (REF)
-Major Diameter (MAX)
-Form Diameter
-Minor Diameter (MIN/MAX)
Circular Space Width
-Max Actual
-Min Effective
Optional Data
-Max Measurement between pins (REF)
-Pin Diameter
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"First they ignore you, then they ridicule you, then they fight you, then you win." - Mahatma Gandhi
assuming they have the standard that you cited.
http://ww
http://w
http://
