Steel Hardness vs. Wear Resistance
APPLICATION: A kingpin and 2 bushings are used on a semi-truck front axle and spindle combination.
Currently, we supply a kingpin that has a higher hardness than the bushing hardness - thus the bushing wears a certain amount for a certain amount of truck useage. By altering the hardnesses of both bushings and kingpins in the test lab the results thus far are less than banner. (No clear equations can easily be derived from the limited data to date).
QUESTION: Does a theoretical equation exist to determine the measured wear of a material based on its hardness? Being a mechanical engineer, I was hopeful to be pointed in a materials direction at least.
BASIC DESIRE: In an application if a kingpin has a hardness of say "X" and a bushing has a hardness of "Y" it will produce measured wear of say "n". Now if the hardness of the kingpin, bushing or both is altered - will the measured wear be altered by a known amount?
kaiserman
kaiserman
Tim Kaiser
VW Kaiser Engineering, Inc.
www.vwkaiser.com
RE: Steel Hardness vs. Wear Resistance
h
Eng-tips come through again. Questions go out - answers come in!
Kaiserman
Tim Kaiser
www.vwkaiser.com
Not as a reward, but a site I believe you will find interesting when it come to wear.
http://www.tribology-abc.com/
