eDrawings - Configurations - Measure
Help!
I finally figured out how to get my part configurations to show up in eDrawings professional BUT... now my measure tool does not work.
Any suggestions?
Brian
SW2007 sp3.1
eDrawings 2007 Professional
RE: eDrawings - Configurations - Measure
There is box to check/un-check to allow/dis-allow users to measure in the eDrawing.
'Save as' -> Select eDrawing as the file type
Click the 'Options' button in the corneer of the window.
Make sure the 'Okay to measure thie eDrawing file' box is checked.
It should be that easy.
Hope this helps,
Lou
GLED, worked perfect.  Thanky You very much.
Brian
