PM sync motor with delta stator convert to wye question
Help... Trying to perform mathematical translation of delta winding to wye type machine. Then will build it to see if truly works similarly. Since this is a PMSM only need to worry about the stator. Does the below look correct??? Any comments and/or suggestions much appreciated!!! :)
Description             Delta             Wye
Stator resistance        Rs              Rs/3
per phase
Stator inductance       Ls              Ls/3
per phase
Back EMF constant      Ke             Ke/sqrt(3)
