Moment of Inertia
Moment of Inertia
Moment of Inertia
Hello
Using the Mass properties in Solidworks allows to plot the principal moments of inertia of a part. But I was really interested in knowing the "total" inertia of the part, not the inertia for each axis. Is there any way to use the moments from each axis to determine this "total" value? any equation or so?
Thanks in advance
RE: Moment of Inertia
Or check the CosmosWorks forum.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Are you thinking of the area moment of inertia or second moment of inertia?  Tools > Section Properties
http://en.wikipedia.org/wiki/Second_moment_of_area
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"First they ignore you, then they ridicule you, then they fight you, then you win." - Mahatma Gandhi
