UBC/IBC Question
UBC/IBC Question
Is there an IBC equivalent (Ss, S1) for UBC Zone 4? Or are the two completely incompatible? Thanks,
ER
ER
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: UBC/IBC Question
They aren't really compatible methods but a while back I tried to work out an equivalent. Note that most comments in the thread did not support what I was trying to do. What I wanted was to develop a rule-of-thumb as a general guideline. It required that you make several assumptions and go partially through the calculations.
The assumptions made regarding site class and the value of R which impact the final answer greatly. Also you need to be careful with strength versus allowable stress which is a factor of 1.4
-Mike
-Mike
