Drill Chart
Drill Chart
Good morning all. Fridays almost here..
I have been trying to create a chart that would allow me to select a drill size, to creating a feature, but when the feature is display on the drawing, I would like it to control the tolerance range of the hole.
Example
I would pick 1/4 drill from the chart, and on the drawing it would display as the following Dia. symbol .248-.247.
Thanks in advance!
Example
Thanks in advance!
Rip
SolidWorks 2007
SP 4.0
RE: Drill Chart
Will the tolerance settings in the feature manager tree work for you? If not, then why not?
Bradley
SolidWorks Premim 2007 x64 SP4.0
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
