oring main seal on b-fly valve
anyone has experience with oring sealing .
We have oring seal on butterfly valve disc. Flow push oring outside its groove.
there nay construction solution to solve and void this problem?
valve is used with water at max 6 bar
in the valve is generated quite hi velocity ...about 1,5 mxsec
henry
RE: oring main seal on b-fly valve
This valve has an o-ring in a groove running around the perimeter of the valve disc?  It will probably always pop out under high differential pressure.  Butterfly valves built for high delta-p have a seal (tadpole or several other styles) that is held in place in the housing.
