increasing voltage input to motor
Good day
I have recommended a motor be swapped with a replacement as the previous design is obselete. There has been a 10 % increase in voltage. The current measurements have also increased, which is expected.
Assuming all parameters remain the same, will the power output of the motor change? Will the same amount of mechanical power be transferred to the shaft?
Thanks in advance
Thanks in advance
RE: increasing voltage input to motor
If the load has increased to your application and your voltage has increased, I would have thought the rated power of your motor must increase unless the current increase is still within the required level for the power rating of the motor. Or am I missing something somewhere?
*Why a man thinks he outrun a chasing dog when it has twice as many legs?*
