create a bending table for a pipe
hi
Is it possible to create a bending table for a pipe which is modeled using Part module.This pipe is modelled using point coordinates. These points are used to produce a polyline with bending radius at some points.The polyline will be used as centre curve and a circle as a profilein rib command.This circle will be swept along with that profile.
Now i want to produce a bend table using this pipe automatically. Is it possible in catiav5.
thank you
thank you
RE: create a bending table for a pipe
http:/
Fernando
If so, you can use http://www
Fernando
thanks for reply,
But I am looking for bending-table for pipes and not design table.
What i need to know is, I am able to create pipe using point coordinates in part module.But after that i need to create a bending table which includes bending angle, twist angle, bending radius,etc for the created pipe.Note that I am not using tubing design.
I believe in order to get the required YBC data( Y=length of straight;B=Rotation Angle;C=Bend Angle ) you would need to use tubing design workbench
Or atleast is it possible to create the bending-table for the by calling the same pipe which is created using point coordinates to tubing design.
i dont have much knowledge about creating the scripts, can you please brief me about that.
thanka again
