Trefftz method
Trefftz method
Hi,everybody,
I've had problems with modeling a HV transmission line using Trefftz method. Could you help me? Thanks!
RE: Trefftz method
I know nothing about this matter so I won't be the one who helps you, but here's a general advice: if you don't specify better what you are trying to do, how you are trying to do it, and what is exactly your problem, only magicians from OZ will be able to help you...
