Bridge Collapse in MN
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Bridge Collapse in MN
Built in 1967. Steel main span over the river with simple spans north and south. The entire section of freeway (several miles) was undergoing surface and other repairs. Some lanes on the bridges were closed and some construction equiment was deployed on portions of the other unused lanes that were under repair.
The collapse apparently started on the south end and progressed northward. Somce sections went quickly and other much slower as people had already stopped. At some expansion joints one side went up and the other went down. The intersting thing was that there was a lateral movement or twisting of some of the spans instead of just vertical.
It will take a good independent professional study to determine the real cause because it was obviously not subjected to classic highway loading conditions.
One of the conclusions being "Since the measured and calculated stress ranges were less than the fatigue threshold, it is concluded that fatigue cracking is not expected in the deck truss of this bridge."
http://www.lrrb.gen.mn.us/PDF/200110.pdf
I'm sure this will get pulled soon....
h
A security camera caught the collapse
Is this the same report that CNN was quoting that determined that there was no redundancy in two planes of the structure and that fatigue would be problem?
CNN also had a professor of civil engineering that went over the design, steel-arch, of this bridge in detail. He summed up his discussion with the statement that in this particular design it only took the failure of one member the truss to cause complete failure.
My own 2 cents freom what I saw (and I know there will be a lot of this)
You just don't see failures initiate and progress perfecly symmetrical within a span like that, leading me to believe that the collapse must have begun on the backspan. It is almost certain that the main span needed the moment contribution from the back spans. Two plausible scenarios are a local deck failure that dropped and the falling mass energy took out an important backspan truss member on the south side, or a failure within the truss at that location, leading to progrsssive collapse on the south side of the south pier, and a complete failure of the main span as a result of unforseen moment deficiency.
Is anyone else having problems reading the right end of everyone's posts? Or is it just me?
I'm having the same problem.
csd
http://en.wikipedia.org/wiki/I-35W_Bridge
It doesn't look like a true cantilevered back span, though I'm not a brige guy
If you look at the pictures, it appears that new concrete on the bridge deck is covered with visqueen. There was supposed to be a thunderstorm later that night.
What happened to the construction workers?
I tried downloading the report that WillisV posted but it is very slow and never finishes. But from what I read, fatigue is a very real issue with this structure.
I suspect foundation failure most likely due to scour. Even though the piers were at the edge of the water, it still looked like they were in the water. I guess it's that or something in an adjacent span that pulled or pushed the main span off its bearings.
It still seem weird the way it dropped straight down.
He also stated in it's day this was a every inexpensive way to construct a bridge, less steel and lots of labor. Today it would be very expensive construction due to labor cost.
Some of you bridge guys help me out a little on this one. He also made the statement that this type of truss would fail completely if any one component failed.
Maybe, the concrete formwork collapsed onto a lower structure member.
Gravity
sorry....I couldn't resist!
Here is the 1/2 sized photo...hopefully this will work better.
The entire bridge did not fail straight down. If you look at the picture below, the bridge did not come straight down at the north end. The debris at the north end of the bridge shows that the top of the north end of the bridge fell or twisted to the west.
The south end of the bridge came straight down, following the failure of the north end.
TTFN
Thst stretch of the Mississippi river is not typical of the area below St. Paul (10-15 miles downstream by water). It ihas lower flows and is carved out of the limsestone that very close to the surface.
Sorry, but I could not see all of my post for corrections
I was just watching the news and they showed the same thing, the support on one end is leaning toward the river.
It showed the support in the water.
I was having trouble with whether this was a camera angle problem or the real thing. They came back to this area in another shot and sure enough the support is leaning.
Didn’t the bridge have a center pier in the water? It looks like it from the one photo. I tried to confirm this from Google Earth, but all I got was a Salvador Dali version of the bridge, melted-looking.
I watched the news conference with the engineers. I believe they mentioned corrosion at the roller bearings. I haven’t worked in bridge engineering for awhile, but this seems worth investigating.
"If you are going to walk on thin ice, you might as well dance!"
http://www.msnbc.msn.com/id/20089341/
Never, but never question engineer's judgement
Checkout the post by JAE at the top of the page
The entire bridge did not fail straight down. If you look at the picture below, the bridge did not come straight down at the south end. The debris at the south end of the bridge shows that the top of the south end of the bridge fell or twisted to the east.
The north end of the bridge came straight down, following the failure at the south end.
If you look at the picture above, it looks like they were pouring concrete.
Does anyone know what that truck is by the concrete hauler.?
NY Times Picture:
Wikipedia Picture:
NY Times Graphic:
One problem with the graphic is that the location of the railroad tracks is different in the birds eye and profile views. My understanding is that the tracks are between the end piers.
Bridge 9340 is a deck truss with steel multi-girder approach spans built in 1967 across the Mississippi River just east of downtown Minneapolis. The approach spans have exhibited several fatigue problems; primarily due to unanticipated out-of-plane distortion of the girders. Although fatigue cracking has not occurred in the deck truss, it has many poor fatigue details on the main truss and floor truss systems. Concern about fatigue cracking in the deck truss is heightened by a lack of redundancy in the main truss system. The detailed fatigue assessment in this report shows that fatigue cracking of the deck truss is not likely. Therefore, replacement of this bridge, and the associated very high cost, may be deferred.
He discusses scary fatigue details and pigeons as identified above by concretemasonry. The report maintains that the truss has a severe lack of redundancy. South approach span initiation still looks credible.
http://onl
Inspection and Management of Bridges with Fracture-Critical Details, Transportation Research Board, 2005
Co-author is Robert Dexter who worked on the 2001 Mn/DOT report.
"Sloan said his crew was placing concrete finish on the bridge for what he called a routine resurfacing project. "It was the final item on this phase of the project. Suddenly the bridge gave way," he said."
For what purpose are the semi truck and loaders used? It looks like it was a material staging area. Is the truck for asphalt, sandblasting, or concrete deck repair?
Milwaukee Journal Picture:
Another Milwaukee Journal Picture of the truck:
Here is another of the construction trucks that look similar to the crashed one.
http:
http:
http:
http:
http:
http:
A flickr search with quite a number of photos:
h
http:
I did not see any K1c evaluations, only stress range.
It would seem to me that a structure subject to -35F could have crack propagation problems that could cause accumlative fatigue that could later cause problems during the summer months.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
An even better photo of the north pier showing its lean:
http://www.flickr.com/photos/diversey/990643158/
Another photo from before the collapse:
ht
I am not sure what that means--did the collapse of the main span precipitate the collapse of the approach spans?
DaveAtkins
That looks like what happened at the north end. With the main span gone the approach span could collapse. I imagine this is why the pier is pushed towards the river - the approach spun thrusted it out of the way as it progressed through its collapse.
However, if the north end piers were leaning and imitated the collapse, the collapse would have started on the north end.
But the CNN video clearly shows the collapse started on the south end. After the main spans collapses, a pause occurs before the north approach span collapses. It is logical that the collapse of the north approach span pushed the north end piers off center.
http://www.dot.state.mn.us/
In the meantime, we should avoid public speculation on the collapse. As some one noted there is a lot of incorrect information in the news. Some ludicrous statements I’ve noted:
“State bridge engineer Dan Dorgan said the bearings could not have been repaired without jacking up the entire deck of the bridge. Because the bearings were not sliding, inspectors concluded the corrosion was not a major issue.” IF THE BEARINGS WERE NOT SLIDING THAT IS A PROBLEM!
"I would be stunned if this didn't have something to do with the construction project," said David Schulz, director of the Infrastructure Technology Institute at Northwestern University. "I think it's a major factor." STICK TO TEACHING!
“This bridge is unique because it was constructed with a single 458 ft steel arch to avoid putting piers in the water which would impede river navigation, according to the U.S. Dept. of Transportation. “ I GUESS THEIR DICTIONARY HAS A DIFFERENT DEFINITION OF UNIQUE.
did they censor your forum?
This in an interesting link that is more related to the other forum:
h
Here is another approach to the detection and monitoring of fatigue cracking on steel structures in real time. I would imagine that all such approaches to automating detection and monitoring of cracking will have tons of money dumped on them shortly.
http://www.matechcorp.com/index.html
Unfortunately politicians are almost all lawyers, who want to find blame in the engineering not the funding....
During a collapse situation damage can occur to the pier, expansion bearing, and other elements that will obviously make it act differently then under normal conditions. The trick is to find out the chain of events from all the different broken, tilted and twisted pieces. Which happen first?
jike is absolutely right, the chain of events needs to be established.
I re-posted in thread765-194020: 35W Failure Investigation
bridgebuster,
That style/type of bearing was quite common on Railroad Bridges in my area several years age.
WVDOH needed a set of plans quickly and when they learned that length and channel clearance of Vicksburg Bridge was more or less what they needed, he got the job.
1. He must consider himself qualified because he took some science classes;
2. He said his wife is an Architect, who had to take some structural engineering classes in school (many years ago).
His (and her) theory is that the vibration of the train running below the bridge at the time is the main culprit, along with the rush hour traffic. Somehow, I don't think it was the first train to use those tracks during rush hour!
(I guess that makes me a Meteorologist, because I have a rain gauge and thermometer in my back yard).
Good news, they reduced the number of missing people from 30 to 8. 5 people are dead so far. I hope there are not a lot of people walking under the bridge when it happens.
Maybe, but I'd rather hear it from someone other than the TV weather geek.
The magnitude of vibrations would be so small that resonance caused by the train is highly unlikely to bring the bridge down.
I think this guy watched one to many tacoma narrows specials
Having an obviously unqualified media person (weatherman) give theories just doesn't help anything. I'm a building structural engineer (as opposed to a bridge structural), and I wouldn't dream of giving any speculations to be aired in public right now, because I just don't feel qualified enough in that area. I'd rather hear what the true experts with experience in bridge design and/or collapses have to say.
The only good to come out of this right now is that it maybe brings some attention to a possibly dangerous condition in other bridges around the country. At least they will be looked at and re-evaluated. The politicians sure seem to be congregating in Minneapolis this week. They know, after Katrina, that how they respond might just have an effect at the polls in the very near future.
The thing is, during her entire 15 seconds of fame, it looks like she never stopped talking on the cell phone during the entire collapse of the bridge. Amazing concentration!
Your statement about the Guy's wife being an Architect got me thinking. Has anyone ever seen the intro for Building it Bigger on the Discovery Channel?? The host claims to know alot about engineering because he went to Architecture school. What a joke!!!
We need to let the engineers on the ground do the investigation and keep the speculation to a minimim as the drive-by media types will run with antyhing that they can use to make someone look like a scapegoat.
Hopefully what will come out of this is an is an increased knowledge, and a greater awareness of the poor state our infrastructure is in. I can believe the numbers being stated of how many bridges in the country are deficient, however, the media does not understand what alot of this data means, which is dangerous. ASCE has been publishing for years the condition of the infrastructure and a believe that our bridges normally get C's and D's.
I felt the response by officials (NTSB, MNDOT, etc.) to collect all historic information, photos and videos, interviews and recovering the debris to determine the real cause was a very positive step. It could be very valuable to the engineering profession.
It sounds like it will be a big project to visually reconstruct the bridge and examine the salvaged components. Despite the current, the odds on collecting all the major components are quite good. The river bottom is quite hard and is native limestone in many places; the depth is not that great (9’ barge channel) and the flow (in terms of volume) is not as great as you would expect. Just downstream there is an area where some debris that was flushed away will collect. – Maybe they will reconstruct it just like an airplane forensics project.
They are currently putting GPS equipment on all of the pertinent points of the structures to determine the present location before anything is moved.
After they get the physical components, they will then have an opportunity to look at the failure points (probably multiple sequenced failures) and then look at the possible causes including the unbalanced loads, vibration, effects of any repair efforts and “terrorism” without the “benefit”(?) of the newscasters and limit the investigation to the engineering facts.
This will hopefully be documentation to put teeth into the move to conduct engineering evaluation of all infrastructures for once.
Dick
Far better than some TV 'personalities' discussing frequencies!
Here is the most traveled bridge in Mn with known deficiencies and the official stance was wait and see what will happen.
The only news reporter that appeared to have any inkling of what was going on was Greta Van Susteren. She asked a questions about the stresses it would take to cause such a failure.
Maybe it will shed light on the fact that our infrastructure is in dire need of repair. If it were not for this tragic incident, the general public would probably not be aware of this, or pay much attention. Maybe we can actually get congress to fund some transportation projects.
I didn't mean this to be a political discussion, just want to know where the money would originate to repair all these bad bridges?
How about repealing the tax decrease for the wealthiest Americans?
When much of our infrastructure was built, dams, interstates, etc. 30s to 60s the top tax bracket ranged from 62% - 92%.
Now its political
He mentioned that they saw a 50 ft "shift" in the southern end if the bridge and that the southern end maybe the point of interest.
This marvelous computer program they have is an FEA program. He had to read what FEA stands for. They are going to use this to take out pieces of the bridge and see where it falls.
The good news, apparently the death toll is going to be as bad as originally thought.
The center of the bridge also appears to have split and zippered apart down the middle of the deck. The split is widest near the mixing truck.
I think the speed of the wave make the bridge appear to be falling straight down in real time.
Hey, not all architects are sitting around picking out pretty colors! When I got out of school, with a BS/Arch, I went to work for a structural consultant that specialized in erection procedure and failure analysis. I modeled failures as well as inspected may structures, from waste digesters to bridges, for all types of distress. I’ve spent long hours in a crane or manlift in Chicago winters trying to find stress cracks in steel structures. I spent seven years doing structural steel shops drawings. My boss was a former chief engineer at American Bridge and Iron. It was an excellent training ground.
Maybe not all architects have had such experience in engineering and failure analysis, and certainly not many female architects, but you can’t start bashing them all or I’m gonna have to start bi!ch slappin’ ya.
Actually, I don’t mean to rant too much, but I don’t like to see the polical/CYA turn the investigation has taken. I think it taints what should be a purely scientific endeavor, regardless of liability. Analyze what happened without first looking to see who has the most money or who you can blame for the most political gain.
And I have some really bad news from the West Coast where I no live. I have received a couple of email from friends I consider intelligent asking me if I heard that it must have been a terrorist bomb and that the Bush administration is keeping secret the real death toll of almost 100 people. I try to explain the current and far more likey theories, but not many are listening.
My new sign off, “For those who believe, no proof is necessary. For those who do not, no proof is possible.”
As a result of all this, the UK politicians have decided to review the bridges in the Uk (must need something to do!)
Our local bridge (not steel) will no doubt be subject to a major inspection...after all, it's been there since 1674....
htt
Agree with all of above re media "experts". Here in the UK we have all sorts of academics on tv, expounding their opinions (for that's all they are) of the cause of failure of a structure some 2000 miles away. I have yet to hear one say "Let's wait until the Engineer's reports are in". But I suppose that is not "News".
Hope you guys over there sort it out without too many politicians getting involved (have not seen a US engineer on the tv yet!!) Condolences to the families of the lost.
Best regards
Harry
I'm not bashing Architects, and gender has nothing to do with it. With the credentials you've listed, you actually sound more like an engineer than an Architect, and I know that there are plenty more like you out there. You actually sound more qualified than most of the people I heard talking about it in the first 24 hours after the collapse.
But, there are also many Architects who don't do anything more than space planning and color selection, and it's those people I don't need to hear weighing in on this - BECAUSE THEY'RE NOT QUALIFIED, even if they did take a structures class in college 15 years ago. I would, and will say the same thing about a structural engineer who is designing only, say, concrete foundations or light gauge structures all day...they are certainly qualified in their own area, but not here. I say the same thing about myself! I'M NOT QUALIFIED TO BE A TV EXPERT ON A MAJOR BRIDGE COLLAPSE.
Hope that clarifies it for you.
I tried to get a report on a recently built bridge that has been under going a lot repair work since it was commissioned. I kept hitting firewalls and finally had to contact a person who had worked on the bridge. They were replacing the inferior grout that had been used to protect the tension cables, he said tendons. This bridge spans the intracoastal waterway and is 1/2 mile from the Gulf of Mexico.
Maui
Why don't you red flag your second post and get the site management to fix the title of the thread. I used to live near where the Mississippi flows alongside the state of MS and I crossed that river many times on each and every one of the bridges that touch MS on one end and if one of those bridges fell.........well, you know. So the title makes my heart jump every time I read it especially the first day before I saw the news and realized that it was MN. The Mississippi is kind of a pup up there, not to minimize the enormity of the tragedy for those who lost loved ones.
rmw
http://w
The hypertext link,
"Minnesota Bridge Rating and Load Posting Report for County and Local Agencies.. " appearing on this page, with a link to this page,
ht
http://virtualpipeline.spaces.msn.com
ht
Look down at the reference to the 2001 inspection statement.
ht
Sidelight:
Hoan Bridge in Minneapolis
ht
GUTLESS BUREAUCRATS: They see engineering recommendations as optional!
NO BRIDGE REHABILITATION "SUPERFUND:" Money and politics should not be a roadblock when it comes to life safety.
INADEQUATE INSPECTION AND EVALUATION PROCEDURES: Bridge engineers should reevaluate their fatigue analysis procedures. They should replace stress range approaches to damage tolerant crack growth procedures.
DESIGNING TO A "NAT'S ASS:" The bridge designer should be using significantly lower allowable stresses for fracture critical details.
Unclesyd - The Hoan bridge is in Milwaukee!
As I read the posts from the beginning I can't beleive some of the writings actually belong to engineers. It's true that infrastructure is aging and needs to be dealt with but some of the rants and raves posted here are no better than lay people, media Zealots or meteorologists.
As for Architects - they should also refrain from commenting, shop drawing review or not as should the folks I've listed above. Experience with steel design especially with buildings be they large, deep plate girders acting as transfer girders doesn't play into this since there is virtually no fatigue cycling in that environment. Fatigue and Fracture Mechanics is a specialty area of engnieering and those who've had a course in it (as I have) will tell you that it is far from exact science and requires dedicated study.
As for the history of the bridge, we scour what we can from teh web, but has it occurred to anyone that we're barely scratching teh surface? This bridge could have been retrofitted or rehabbed for other purposes and we have no idea what or how it could have been modified or how those modificatinos affected the original behavior.
So please let's not act like the very people we curse upon hearing mis-information.
Qshake
Qshake,
You and I have been around and about enough to see the same refrain form the bureaucrats when they come out with explanations and hyperbole, along with dancing, around any event such as this. I know that most bridge engineers and professors can't speak out about things like this if they want to keep their job or get grants.
I think it about time more people, maybe not the best informed, get concerned and rant a little until the next bridge fails.
I asked for I would not expect someone who is unfamiliar with this type of bridge design to reply to my question, nor would I want them to. But if someone is experienced, trained, and qualified to provide the requested information, and they are inclined to do so, then it does not speak ill of them (or others) to formulate an appropriate reply. Each case is different, and a failure analysis must be performed to determine the specific reasons for the collapse. But if we followed the same line of reasoning that you provided in response to my question, very few engineering questions would ever receive replies on this website.
Maui
With all due respect, at this point all there can be is speculation even from experienced bridge designers until the forensic report is published.
I have some fatigue and fracture analysis experience for other structures. What I don't understand is how bridge engineers can determine the life of a cracked structure using stress range approach. Once you have a significant crack, the stress range approach is meaningless and fracture mechanics is necessary to determine an estimate of remaining life to failure.
David N Watson, P.E.
Drummond Company, Inc.
www.drummondco.com
Some of what is said above is useful, or at least insightful because it comes from a different point of view. Notice how nearly all of the structurals zero in on the steel, while the civil guys seem to focus on the foundations. Besides isn't the point of this thread a collaboration of thoughts & evidence from engineers of all disciplines. Offer up some helpful thoughts for the discussion.
Maui - one would have to have 'exact' experience in order to speak expertly on this matter. I am not aware of any similar bridge collapses.
darkwing - back to fracture and fatigue mechanics in bridges. Unlike the fracture and fatigue evaluations that GE or Honeywell or the DOD or Boeing or pressure vessel manufactures might undergo to determine the remaining life of a structure or element within a structure, once a bridge member cracks and is found and noted in an inspection, the crack is usually arrested via a arrestor hole drilled in. It is further watched as are the surrounding members and or similar members.
If the crack cannot be controlled by those means, the member or part thereof is typically replaced. The bridge industry does not engage in fracture studies as I point out may occur in other industries/companies.
That said, there are numerous bridge structures still performing well today with cracks and arrestor holes.
Steelmover - there are many, many different areas that could have, in concert, acted to collapse the bridge.....I don't see the point in speculating about all of them.
Qshake
the open lanes, also, should distribute
more load to some members than they were
designed for. I like to see if this has to
do anything with the failure.
Maui
The questions that I had brought up earlier have not been answered. Is there a report that evaluates the state of stress with a hole at the end of the crack? A K1c calculation before and after the "fix" should have been made.
How many cracks and/or their density could exist before the margins of safety of the bridge is jepordized?
I think that there could be numerous reasons that could be listed here by bridge engineers on this site. Just not likely reasons.
Saying "likely" implies that there is knowlege available to rate each reason's probability. I agree with Qshake that no one except those directly investigating the bridge can even come close to that "likely" position.
(Its amazing how much dust you can shake from the rafters with only a couple hundred watts)
http://ww
As to why it fell when it did, lots of corrosion issues and fatigue cracks, but as to the 'straw that broke the camel's back,' I have a hunch that the cement truck is mentioned in the final report.
I'm with BigInch on this one it looks like this one hasn't been painted for a while if ever. I would hate to guess the millage on the last paint job. The coating appears to be similar to military lead based olive drab primer.
The rust spots could be where the inspector cleaned the area for testing, any bets.
The forensic investigation seems to be focusing on the weights of the construction equipment and materials. It would be interesting to see the scale weight tickets for the trucks.
ht
Several times I've seen where a RR crane would lift one end of an highway overpass and people would work on the bearing/supports.
In the 90's a friend got the contract to remove several RR/highway overpasses and his method was just pick it up and set it one the ground. They unbolted nothing, in fact getting the bearing off the support piers was lot bigger problem than taking down the overpass.
I also heard a statement that to replace a frozen bearing on this bridge that the entire bridge would have to be shut down. I am sure they were told to find another way to do it.
One thing that I know for sure is that alot of political pressure would come to bear to not shut down the busiest Interstate bridge in Minnesota. This may wind up being alot of finger pointing between the engineers and the politicians
The URS report shows a scaled-down version of an original contract drawing of the elevation. Based on the drawing, the pier in the photo posted by bimr might be pile supported and the pier in the river (at the other end of the mainspan) looks like the footing could be resting on a tremie pour or caisson.
unclesyd - your theory might have possibilities. I saw a news flash that said the construction workers told investigators that the bridge was "wobbling" for several days. If by "wobbling" they meant an effect, for example, similar to the rocking of a table with on leg shorter than the others, that could point to a loss of a support, possibly at the south because that truss backspan is twisted whereas the other spans appear to have dropped straight down.
The first panel of each backspan is a 38' long cantilever that is also skewed. Skews do cause superstructure movements.
"As a summary, the bearing measurement data indicates that the bridge expansion bearings are not functioning as designed. There have been notations in previous bridge inspection reports referring to 'frozen' rocker bearings and corrosion and section loss at the truss roller bearings. The erratic nature of the bearing measurements can be explained by the bearings components 'sticking' in place. There is enough frictional resistance due to corrosion and debris to keep the bearing from moving until there is enough thermal force built up in the system to cause a drastic and quick movement of the bearing to relieve the force. The bearings are not allowing the structure to move linearly with changes in the ambient temperature".
I would not be surprised if these "frozen" bearings were found to be a significant factor in the collapse. Being one of the hottest days of the year with the bearings restraining longitudinal movement, a "quick movement" could have occurred to cause an existing crack (in one of the many fracture critical members that by definition has no redundancy) to reach critical crack length and complete member failure causing the bridge to collapse.
The construction equipment has been mentioned several times as a possible contributor to the failure. This is an 8 lane bridge and 4 lanes were shutdown for the construction. My question is similar to one of the above posts.
How many cement trucks equate to 2 lanes of bumper to bumber moving traffic?
Could one cement truck and one site mixer and 4 "Georgia Buggies" cause an eccentric loading.,either +/- when balanced against the traffic on the other side?
I don't believe one concrete truck, one site mixer and buggies would even begin to come close to the design loads for that bridge. The sway frames between trusses would be designed for any unbalanced loads.
The frozen bearings and the resulting build up of thermal forces could have caused a truss member to fail, a connection to fail, the bearing anchorage to shear, the top of the pier to break off, the pier to tilt or the foundation to fail. The "wobbling" feeling that the workers describe only make me more suspicious of this type of failure. I only wish they had said something at that time!
The mention of wobbling by the construction crew might have alerted someone, but wasn't someone for the WDOT overseeing the work. It just sounds all too familiar.
I have an ex-technician that use to work for our group and is now a bridge inspector for a large easter state. His qualificans are CWI, Level II MT, PT, RT with 25 years experiences. About a month ago while back home he and I were discussing his job. He said it is mostly paper work with very little actual inspection. He stated that one recent job he was on a hurry up/catch up inspection on a steel bridge that had fallen off the radar. He stated that at quitting time on day while they were in the steel work the whole crew heard a very loud bang. He stated that it was so loud that you could tell the direction. It was duly noted in daily notes and next morning when the supervisor was asked the commented that this is common occurrence and don't worry about it.
I just called him and asked for a little more information about the particular bridge. He said the type was listed as modified truss and had both bolts and rivets. They biggest problem the found was loose bolts and the normal paint problems. There had been some remedial work on the bridge. He also stated that it wasn't unusual for comment lines to be taken from the daily's.
"Some workers said that the bridge had been wobbling unusually in the days before the collapse. With every layer of concrete that they removed, the bridge would wobble even more," the paper says, citing reports from Minneapolis police Sgt. Tim Hoeppner.
From this USA Today photo, it appears that two lanes had the deck surface partially removed for the entire length of the entire bridge.
It is too big of a coincidence that the construction was ongoing when the bridge collapsed. What about the effect of too much weight on a bridge deck with a surface that was partially removed?
Dan - Owner
http://www.Hi-TecDesigns.com
The first panel for each of the truss spans extends (or cantilevers)from the pier. (The diagonal member from the pier could be called a strut and the upper truss chord could be called a tie.) The far end of each of these panels forms a hinge with the girder approach spans.
unclesyd - A loaded concrete truck is probably 32 to 36 tons. Two lanes in each direction were closed and on some newscasts there was talk about the unbalanced traffic loading. I doubt that this caused the collapse. For example, if just the two outer lanes in one direction were fully loaded (assuming AASHTO lane load)there would be a LIVE LOAD uplift on the opposite truss. However, the dead load would counter the uplift.
From the aerial pictures it wasn't bumper-to-bumper trucks.
We return to the gutless bureaucrats and politics...
Perhaps the deck may have been carrying the build up of thermal stresses and when the deck was partially removed those stresses had to go somewhere (top chords of the trusses). Vibration may have also triggered the release of some of these built up thermal stresses.
This, of course, is all speculation and needs to be proven by the investigators.
Does someone know if there was a horizontal truss between the top chords of the main carrying trusses?
I was curious whether there were any truss members in the horizontal plane directly beneath the deck. It looks like there might be but then again my eyes might be fooling me.
Whether it is the bracing element of the truss top chord, I am not sure. This why I ask the question whether there was any truss members in the horizontal plane just below the deck or stringers. For a bridge of this size, I would guess there is just so it could be erected safely and to maintain truss stability for deck replacement.
The roadway stringers sit on transverse trusses rather than floorbeams. The trusses were probably used for economy considering the large cantilever (in the transverse direction) of the roadway.
Page 3-25 provides some description of the foundations.
I don't think neglecting the grade of the bridge in the analysis is a big deal; it's less than 1% over the length of the bridge (Page 4-13). The cross-slope of the deck doesn't need to be considered; both trusses are at the same elevation.
Is it OK to neglect the horizontal curvature? It looks as though it's within the AASHTO parameters. Should they have done so, hard to say? Particularly if the collapse was the result of a bearing failure at Pier 5. Skews always produce a racking force; without doing our own analysis we can't say what the effect would be in this case.
Land to the East of the bridge pulled East.
SOZT 8/2/2007
We have predicted that bridges crossing the Mississippi will be affected when the New Madrid and related fault lines adjust, going into the pole shift. Was this bridge collapse which crossed the Mississippi in Minnesota caused by such an adjustment, the footings on one side of the bridge moving in an opposite direction from the footings on the other side, or perhaps the bridge being pulled apart? The Mississippi River is born in Minnesota, tumbling out of the headwaters in the highlands of Minnesota over a series of natural falls. This is a clue that adjustments in the rock strata could be involved. The highlands of Minnesota come to a point at Minneapolis, with lower land lying to the East along this point. What caused the land to the East to drop, unless this land was stretched in the past? We have stated that the ripping apart of the St. Lawrence Seaway ends in the rumpled Black Hills of SD. Run a line from Montreal, at the mouth of the seaway, to Rapid City, SD and the line runs through Minneapolis. Why would an adjustment be made in the MIDDLE of this stretch zone while the seaway itself did not part? When we described the diagonal pull the N American continent is enduring, and just how this will snap when adjustments are made, we did not intend that this process would occur smoothly, all at once as described. Weak points along the rip lines give way one by one, each such adjustment placing stress on other points in a domino manner. The I35W bridge, being the larger of the bridges crossing the Mississippi at this point, was less able to adapt to a change in position vs-a-vs its footings on either side of the river, as it was an interstate bridge supporting several lanes, and thus had massive and thus rigid supports. Smaller bridges have more flexibility as they are built to withstand uneven loads on either end, thus are more springy by design. Will there be more such disasters along the Mississippi and in the cities that will be affected by the New Madrid and seaway rip? This is just the start, and when the pace picks up, there will be no question that something OTHER than Global Warming is the cause.
EOZT
Bridge collapse probe focuses on unexplained shift
Aug 3, 2007
http://www.cnn.com/2007/US/08/03/bridge.structure/
Investigators trying to figure out what caused Wednesday's massive bridge collapse are focusing on the southern end of the span, which "behaved differently" as it fell, the National Transportation Safety Board said Friday. The NTSB says one part of the bridge shifted 50 feet as it fell, while other sections collapsed in place. What's getting investigators' attention is the way the southern part of the bridge fell in a video they've already examined -- recorded by a security camera near the bridge's north end -- and the way the section settled after the collapse. It appears that it has shifted approximately 50 feet to the east and when we compare that to what we've seen in the rest of the bridge -- the rest of the bridge appears to have collapsed in place.
---------- Original Message ----------------------------------
Reply-To: humvee@myway.com
Date: Fri, 3 Aug 2007 16:06:07 -0400 (EDT)
>Nancy: Was the collapse of the I-35 bridge across the Mississippi River in Minneapolis due to the land on the west end of the bridge moving NW in relation to the eastern end moving to the SE?
NTSB says bridge shift wasn't cause of collapse
http://www.ydr.com/newsfull/ci_6546111
There was no "unexplained shift". After the collapse of the main span, the south approach deck tipped over in a secondary collapse like a house of cards, falling towards the west.
You would have to have an "unexplained shift" in the north south direction to pull the bridge off the supports and that did not happen.
http://www.fhwa.dot.gov/pressroom/sdtbinv.htm
When the bridge fell, a construction crew was replacing part of the bridge deck, transportation officials said.
Workers were shaving about 2 inches of concrete off 9-inch-thick slabs and replacing them with 2 fresh inches of concrete.
Workers were replacing all 9 inches in about eight parts of the bridge.
"In some parts, the 7 inches wasn't good enough quality," McFarlin said.
http://www.twincities.com/allheadlines/ci_6557477
h
Was the 35W bridge always a concrete deck design?
By my reading, the fatigue cracking which was observed and addressed by drilling was in the approach girder sections, not in the truss spans.
The lateral load was apparently taken by a horizontal truss at deck level which spanned the full 990 ft. Can anyone confirm this? The problem with that is that the main supports at the river edge may have tried to take the lateral load without the capacity to do so, especially with the deteriorated state of the bearings and vertical web members above the concrete columns.
Perhaps the requirement to close down the bridge to replace bearings was a safety concern rather than a limition on capacity of the jacking mechanisms.
The concrete deck was divided into a lot of sections by expansion joints, so don't think it was supposed to have a role in stability.
Don't know why some reports called it a steel deck bridge.
hokie66 - the lateral forces are taken by two horizontal trusses; one below the deck and the other at the bottom of the main trusses. The forces from the upper lateral system are transferred to the piers by a series of vertical trusses, called portals, installed between the main trusses.
Where the roadway goes between trusses or girders we call it a through bridge.
It is the bottom-line motivation of the private sector that leads to corner-cutting and shoddy construction such as the problems found with the Big Dig. And every weird unbuildable bridge design I come across has come from a private consultant, not a state-employed designer.
Capitalism is not the One True Answer.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
The management thinks that being a PM boils down to watching budgets, meeting revenue targets, and keeping your staff entertained. Unfortunately, with all the corporate bureacracy we have to deal there's not enough time to deal with the engineering. Then they wonder why the company wide turnover rate exceeded 20% again.
Winston Churchill suggested that democracy is the worst form of political system--except for all the rest.
He might well have suggested the same for capitalism as a form of economic organization.
Capitalism may be the "least worst" of the alternatives available to societies.
A link to an article by "Bridges" magazine:
http://www.gobridges.com/article.asp?id=2277
A link to the I-35W webite:
http://www.dot.state.mn.us/i35wbridge/
I don't know what happened.
I have some theories as to what could have happened but I don't have access to the information necessary to figure it out. I suspect it will take some time for the NTSB to find the critical initiation point.
I don't recall where, but I thought I saw a video of the bridge collapsing where it appeard the first span collapsed, then the middle span, and then the final span of the three span continuous steel deck truss bridge.
This causes me to believe there was a particular failure in the first span. The collapse of the middle and final spans was very possibly caused as a chain reaction to the collapse of the first span.
I don't have the time to discuss all the mis-information I am hearing. This is a technical subject, not unlike medicine or the law, which requires an individual to have a particular vocabulary. However, for some reason, everyone thinks that engineering is earthy enough that everyone should understand what it is about, I guess because they can put their hand on the problem. Any misunderstanding regarding engineering issues is frequently attributed to the engineer's inability to communicate. I believe it is most often the lack of knowledge on the part of the audience that causes them to think they understand what they just do not.
I recommend we all just sit back and let the NTSB and the Minnesota bridge community figure out what initiated the failure. The information will get to the proper authorities in due course. - Dinosaur
J
The statement "I don't recall where, but I thought I saw a video of the bridge collapsing where it appeard the first span collapsed, then the middle span, and then the final span of the three span continuous steel deck truss bridge." is incorrect.
Suggest that you red flag your post.
The collapse originated in the middle span and the collapse of the middle span triggered collapses in adjacent spans.
The original drawings are now available from MN DOT. The south end could be the problem; the framing is a bit unusual.
Spans 3 through 5 are made up of continuous curved girders; the roadway is superelevated west to east (east being the high side.)
At the north end of Span 5 the girders frame into an end floorbeam at the beginning of the truss (Span 6). (At first glance the connection of the FB to truss (Sheet 19 of 94) is unusual. I have to look for more details) The roadway on Span 6 is also superelevated, transitioning to a normal crown at Pier 6/beginning of Span 7 (River Span).
All curved girder superstructure experiences uplift; the inner girders are the ones most affected.
enough said for now.
Maybe this forum is not the place to discuss politics, but if we had some engineers in politics rather than nothing but lawyers, I think our infrastructure would not be in such sad shape.
"We don't believe the southern portion of the bridge is where the accident began," he said Saturday afternoon."
h
"The south end of the bridge fell to the ground during the accident, but investigators have already determined that the stresses that caused the bridge collapse did not begin on the south end. The focus shifted over the weekend to the north and center bridge sections."
http://
"Meanwhile, federal investigators trying to determine where the collapse began said that after closer examination, they had decided to shift their focus away from the south end of the bridge. That section shifted 81 feet during the collapse, but investigators now say they found no indications that was where the failure began."
ht
The dead giveaway is the phrase: "I wish to thank......".
Other witnesses stated that they saw the south end go first.
The only way I can see the north end initiating the collapse is if it failed away from the central span somehow, pulling the south end off its support and causing it (the south end) to FALL first.
Agree with you. It seems that the collapse started in the vicinity of the Contractor's bulk cement semi-truck trailer close to the south end of the middle span. Once the middle span had fallen, the north and south spans then collapsed.
I was just responding to some of the recent posts above that have incorrect information and are outdated.
I don't know how a statement saying, "I don't know ..." followed by "... it appeared to me ..." is mis-information. Are you saying it didn't appear to me that way?
darkwing88,
Several posters early in the thread stated they wanted to hear from someone with the right training/background what was really going on there. For this reason I provided some of my credentials, not to inmply I know more than anyone else. Then I followed with the statement that I don't know what exactly happened to initiate the failure. This was intended to illustrate my view that unless you are on the ground you don't have access to the information to know exactly what happened, and I don't think the NTSB will have the information for some time to come.
I can't fathom how you two were offended by my post.
Maui
http://www.conphoto.net/collapse.html
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
Here is your statement;
The Corp of Engineers security camera video that was playing on CNN only shows the middle span and the north end span. It is impossible to see the south end span on the video because of the camera angle.
Unless you have another video, how could you possibly see something (the south end span collapsing) that is not on the video?
http://w
For instance:
"If there was a design error in the 1960s, failure to identify it before the bridge collapse indicates a problem with the federal inspection program, said Thomas M. Downs, who was the associate administrator of the Federal Highway Administration from 1978 to 1980. "
Either he was mis-quoted or expressed himself badly. Rouine bridge inspection does not include a review of design calculations.
A bridge inspection often includes a calculated load rating, based on observed section loss. If the gusset plates were underdesigned, and then had some section loss, then an inspection could have picked up a rating deficiency.
I've performed several hundred bridge inspections, including several long-span trusses. Mr. Downs is mixing apples and oranges or perhaps he fails to see the difference between a Granny Smith and a MacIntosh.
Yes, an inspection is "to verify to some extent that the design is holding up as intended." However, when assessing components the criteria is "functioning as designed." The inspector isn't expected to give an assessment of the stress level in a main member.
Stress levels can be determined by strain gauge measurements but this is not part of a typical inspection; and it's costly.
"A bridge inspection often includes a calculated load rating, based on observed section loss. If the gusset plates were underdesigned, and then had some section loss, then an inspection could have picked up a rating deficiency."
Not all inspections include load ratings; although they should if section loss is observed. Suppose the plates were underdesigned and had no section loss? An inspector wouldn't know there was a design deficiency, unless the plate was glaringly thin when compared to a similar bridge. A load rating might uncover this deficiency. An underdesigned plate doesn't necessarily make the bridge unsafe: It reduces the design live load and the bridge would need to be posted accordingly.
There are two ratings: Inventory and Operating. Inventory is the maximum truck load that can be used for an indefinite period; Operating is the maximum permissible overload.
The thing with bridge inspection or building inspection, or any other structure is understanding how the structure is supposed to behave; how all the parts work together; what happens if one or more parts fail.
There are times when you look at something and know that it's wrong but there are plenty of times when the inspector will have now way of knowing that the girder should have been 52" deep and not 48" deep.
I've performed part of a rehabilitation study for a bridge similar to 9340, so your experience far outweighs mine. We did inventory and operating ratings for all the bridge components. Because our rehab included an inspection of the bridge, I was confusing an "inspection" with a "rehab study". So you're right, an inspection would not necessarily include a rating analysis.
As you say, if there was no section loss, then there would be no reason to question the rating of the gussets. I was merely trying to make sense of Mr. Downs remark.
http://www.ntsb.gov/Pressrel/2007/080807.htm
If I'm an owner and I have a failure of a structure I had an engineer "inspect" I'm having a hard time understanding why he would miss something so obvious that it would cause a failure - even if there was no "section loss".
This has been a sticky point for our firm in the past. Especially for buildings where the original drawings are not available and/or the original design intent is not clear.
http:/
http://www.startribune.com/562/story/1352036.html
Tom G. Peterson - if you're part of this forum, I give you 10 stars!
Let's give Tom Peterson 20 stars.
I would be willing to bet that a truck of some sort or a piece of equiptment "Fell through" a section of the bridge deck that was previously milled and was being prepped for re-surfacing. I read in a previous post that some portions of the bridge were undergoing a full depth deck replacement and other portions were undergoing partial depth deck replacement.
Perhaps a truck drove over a portion of concrete that was not fully curred or a section that was milled and not capable of supporting the full weight of a piece of construction equiptment.
You should be able to completly remove the deck from the superstructure without failure if the superstructure is stable.
Overloading of the bridge with construction equiptment is a non issue in my opinion. The fact that there were loaders,tankers and trucks of different sorts on the bridge is minimal compaired to the normal traffic that crosses the bridge on a daily basis when all lanes are open.
I dont think vibration from jackhammers would be an issue either. The DOT doesnt allow the use of large hammers on a bridge deck. If im not mistaken the max size allowable hammer is only about 17 lbs. vurses a 60 or 90 lb hammer which is much more destructive and the only reason for the smaller hammer is to lessen fractures in areas not to be re-surfaced.
A previous poster suggested that maybe formwork fell, striking a structural member thus collapsing it. I dont think so, 2x4's and plywood dont weigh that much or at least not enough to collapse a structure of this size unless the structure was in a state of total dis repair. Even if the formwork was filled with concrete, a 9" deep deck spread out over many sq ft dropping on an open girder structure would not cause too much damage. It would be different had it been a box girder type structure.
It has been reported that the state selected the option of inspection only, but I don't see that option listed, unless NDE was interpreted as visual examination only. There was apparently a lot of interpretation of this report by managers and politicians, with the objective of not doing anything. And the report dealt with corrosion only in a peripheral manner. The state's bridge inspectors wrote about corrosion, but again, nothing was done.
I really feel for the pour souls who had a personal moment of H*** as they went down into the river, not being able to get out, or never realizing what happened. Makes me realize how vitally important the work I do is, and how it impacts the lives of others. Note that the root word of vital is vita or "LIFE". Life safety.
Mike McCann
McCann Engineering
h
http://
At the time of the collapse, 18 construction workers from PCI were on the bridge. The National Transportation Safety Board is looking at the heavy equipment, including front-end loaders, the crew placed on the bridge. It's also asking about the weight, quantities of rock and other materials that sat on the bridge.
MnDOT spokesman Bob McFarlin said on that Wednesday, the crew was half finished with its job. It included resurfacing a few inches of the deck in some areas.
"In some areas of the bridge there was a complete concrete replacement, which means taking out the entire nine inches and replacing it with nine inches. And that was in eight spots along the bridge," said McFarlin.
Ripping off portions of the entire deck, professor Astaneh says, is playing with its structure. He says as a bridge weakens, the deck picks up some of the slack. It starts supporting the weight of the traffic and the bridge itself.
If a slab was removed over a fatigue crack or near an unnoticed crack, that could destabilize the bridge's delicate weight balance.
"That's not good news. That's another little storm coming in," said Astaneh. "So they're going to compound, and you're going to have all these little effects, which by themselves might not be critical to collapse the bridge."
Those little storms, as he calls them, include the heavy traffic of industrial trucks and daily commuters, the additional lanes that may have changed the balance of stress on the bridge, the fatigue cracks that were difficult to see, and the lack of structural redundancy. The bridge also faced environmental problems from water, ice and salt.
h
Obviously, the analysis will prove this out one way or another.
The photo also looks like the plate might be bent like the bottom chord is not straight. Or could this be a distortion of the photograph?
Wrong. At least they redefine "fracture critical" a little better a couple of paragraphs down.
Hg
http
"You cannot overplay the gusset design issue," the source said. "
http://www.twincities.com/ci_6577877?source=rss
I didn't know we stopped using welding; nevertheless, a good article overall.
It is my view that the two in-depth inspections should be used in conjunction with a calibrated analytical model of the bridge components to assess the "fracture critical state" of the bridge. Included in this model should be an orthotropic deck.
From a detailed inspection, a map of the discrepencies can be developed. Missing bolts, bearing conditions, cracks (location and length)and corrosion (location and extent) can be identified. The effect of these discrepencies can then be introduced into the analytical model. New fixity conditions can be determined for each affected structural member and included as adjustments of the model. Then new critical load paths can be established. Either a buckling or stress ( with K1, K2, and K3 fracture modes) criterion should be used as the final evaluation for integrity.
If there is no plan to incoporate the inspection results into an engineering assessment, then why inspect the bridge? A critical assessment of the extent of a discrepency should be known, a priori, especially those bridges that have been designated as "non-redundant." If the standards of bridge design do not have specific recommendations as to fixes and the ramifications of these fixes on structural integrity, then what good are they?
There have been studies performed by this author that shows that the life of a structure with small cracks can be exteded (almost doubled) by treating the tip of the crack. By establishing a compressive zone immediately infront of the crack, one can arrest its growth. I see no need to apply a 2 to 4 inch diameter holes as suggested by the standard.
Until a collapse mechanism(s)is found it is far too early to pass on learned knowledge from this tragedy. All there is now are a few educated guesses from experienced bridge engineers and many wild ass guesses from laypeople.
Speaking from experience, wherein possible, cracks and other physical distress are modeled in a rating analysis of bridges. This is not always the case though and is an area of improvement.
As for the standard of arrestor holes, this is viewed as the most effective means of crack extension mitigation. I don't see how your proposal of introducing compression at the crack tip can be accomplished in many cases considering the geometry of the members and ensure that it is reliable once in place. Clearly if it were reliable it would be a standard in use today. It's not very practical.
Qshake
Using the risk assessment example, if risk had been evaluated for this bridge, more proactive O&M might have been considered necessary. Even using a qualitative assesment, the bridge would be considered high risk. Probability of failure due to fatigue cracking, age, lack of redundancy, ship collision, etc. would have certainly been higher than normal. And consequence of failure for this bridge are very high due to the high traffic volume, economic impacts, environmental impacts, loss of life and cost to replace. A risk assessment would have likely shown this bridge to be at the high end of the risk spectrum as compared to other bridges in the state. Perhaps a new model for evaluating bridges should be considered.
RE: Bridge Collapse in MN
I agree that the actual rating analysis should be more quantitative providing a probability of failure, rather than a number which means it is more likely to collapse or not. At the very least, all fracture critical structures should undergo this type of analysis.
Qshake
Theoretically seems plausible, realistically, I don't know that it would help much.
DOT has a certain amount of funds available and subjectively allocates funds to repairs, maintenance, bridge widening, new bridges, etc. Bridge widening and new bridges seem to be heavily favored by the public (spending money to repair a bridge isn't as noticeable to Joe Driver as a new bridge or bridges with more lanes).
This and other bridges are/were identified with problems. There probably needs to be some statistical analysis to delineate when a particular rating factor an existing deficient bridge supersedes a factor for new / widening bridge project.
Maybe something like:
Project Priority Index (PPI) = Risk Factor x Demand Factor x Benefit Factor
Bridge that collapsed Some New Bridge
Risk Factor 9 1
Demand Factor 2 8
Benefit Factor 3 4
PPI 54 32
Certainly crude, the gurus would have to work out the details probably with some weighting factors on each component of the formula.
I guess I'm basically agreeing with you, but just pointing out the public/political motivations for new / widenings have to influence the formula somehow.
What in the hell ever happened to the find it and fix it philospohy when it come to a fabricated structure.
Glad to join you in trouble. The inspectors found a host of things wrong with that bridge, but the managers, risk assessors, fuzzy thinkers, bean counters, politicians, etc. dithered. And now they would like nothing better than to blame it on the long dead designers.
Dam Safety History
1972 Failure of Buffalo Creek Dam, West Virginia; 125 deaths
1972 PL 92-367 the National Dam Inspection Act of 1972
1976 Teton Dam Failure; $1 Billion in losses and 14 deaths
1977 Kelly Barnes Dam Failure; 39 deaths
1978 Corps of Engineers begins the National Inspection Program
1979 Federal Guidelines for Dam Safety prepared
1979 Executive Order 12148 from President Carter created FEMA; FEMA Director to coordinate Federal Dam
Safety efforts
1979 Memorandum from President Carter requiring the head of each Federal dam safety agency to implement the
Federal Guidelines
1982 the National Program of Inspection of Non-Federal Dams completed and National Inventory updated by
USACE; Final Report to Congress
There's not enough budget to fix everything that you find.
You might be interested to look here:
http://www.fhwa.dot.gov/bridge/nbis/index.htm#10
Especially around question: Q313-18
It still comes back to priorities. It would be interesting to see where the DOT had the repairs slated in their long range plan.
I agreed that the money needed to fix everything you find is not available as the monies have been spent in other places for other things. It just passed through the bridge fixing fund on the way to some bridge to nowhere.
Though I've never specifically be tasked with a bridge inspection I've assisted in the inspection of several large steel structures. One was a giant coal unloading gantry that was to be inspected as bolts were falling out and hitting the coal barges. As we were ascending the gantry for visual, MT, and PT testing it was evident that a major problem existed. Everywhere we looked there were major cracks and broken welds. I took the inspection crew down and conferred with the owner and much to his chagrin I told him that any inspection was useless and a waste of money was until he fixed the major problems. I offered to leave 2 technicians to mark all visible defects for repair. He opted out and and about three months later after another NDT company performed a thorough inspection and while waiting for an engineering evaluation a component of the gantry fell and severely injured two crewmen on a tug.
The moral of this tale is fix the obvious and mark the minor deficiencies for later. It appears to me that too much emphasis is put on finding the small fatigue cracks for study, evaluation, monitoring and ignoring the obvious like a warped gusset plate or a slightly bent member, etc.
Stop drilling a crack is just a band aid especially if you return and the crack and breached the stop hole.
Another thing that bothers me is that the people responsible for the inspecting and repairs are investigating themselves.
I don't know anything about how risk assessment of dams is done, but it seems to me that all the steps necessary to determine the risk of this bridge had been taken except to proceed to address the risk. If the corrosion, fatigued members, and frozen bearings had been dealt with, we would not be having this conversation.
TTFN
A few years ago I was involved in a tunnel design project and we did a RA for that reason. It is useful and forces everyone to think more deeply about various types of failures and their consequences.
AASHTO has developed guidelines for its implementation
How would the number of permissible fatalities be determined say for a 10 car, 100 car, or a 1000 car bridge?
A prime example of RA failure is the tragic loss of the space shuttle Columbia with all it's crew. You might throw in the Challenger, though like bridges a little politics entered inot the picture. NASA was the daddy of RA.
It's fairly simple to rank the importance of bridge components and understand the consequence of their failure.
Identifying the hazards (especially the non-structral) can be fuzzy, although there are consultants who specialize in this area.
How much damage or potential loss of life is acceptable? It's a political decision. And the decision is somewhere between Dirty Harry ("Are you feeling lucky today?") and Josef Stalin ("If one man dies it's a tragedy; if a million die, it's a statistic.")
Each vulnerability is identified through a qualitative process. It's a very useful tool. The process helps to identify potential problems and prioritize where funds are best spent.
The following is a link to their website:
https://w
It's not the same as the risk assessment concept, which is being used by some agencies to address terrorist threats.
https://ww
h
htt
Quoting from Risk-Based Decision Making in Water Resources
Proceedings of 4th Conference/EF/WR Div./ASCE
Santa Barbara, CA/October 15-20, 1989
From a paper by David S. Bowles.
"The assessment of human safety can be presented as a histogram of probabilities of life loss events, or the cost-to-save-a-life. The latter should not be confused with placing a value on human life, which is entirely different. The cost-to-save-a-life is calculated as the cost by which a rehabilitation alternative exceeds its economic benefits expressed per life that would be expected to be saved by investing in the alternative. Thus, it can be considered as the cost of providing safety on a per-life-saved basis. Comparisons can be made with the cost-to-save-a-life that society is willing to pay in other areas involving involuntary risks, such as environmental risks, in order to judge acceptable levels of investment in public safety. It is also possible to calculate the expected number of lives that would be lost on an annual basis (similar to risk cost); however, this generally results in relatively small numbers, which are difficult to interpret. Other approaches to quantifying human safety are therefore considered to be preferable."
"The decision is especially sensitive and difficult where lives are at risk, or where large investments will be required to improve safety with little or no effect on project benefits, except of course to their expected longevity considering the reduced likelihood of dam failure."
I'll give him credit for one statement, "Risk Assessment procedures cannot be substituted for good engineering".
Well, he is trying to simply look at the inverse of lives lost...i.e. cost of lives saved. That is a much more pleasant way of looking at it I'll admit.
But the other key phrase here is "comparison....with other areas of risk."
That is, or should be the main focus of any economic/risk evaluation. That you have multiple ways to spend your money to mitigate risk in society or add to the general welfare.
Raising millions of dollars in taxes to simply flood the bridge construction market will definitely save lives. But perhaps more lives could be saved in many other ways for the same dollar.
The bearings froze.
The supports moved.
Problems with expansion joints.
Chronology of 35W
Posted by prost
http://2
&u=www.st
Look at the Forensic Inspection Report for the Dunn Memorial Bridge Ramp Structural Failure on the following site.
Posted by bridgebusters
https://ww
The Roebling canal crossing you mentioned, is that the one in the vicinity of Lackawaxen PA?
Considering thermal expansion on a long span of this design (35W) what would happen if both ends were locked either at the bearings or the first expansion joints and one end was suddenly released, earthquake style?
If the ends were locked would thermal expansion cause the center of the arches to rise or would the expansion be taken up by elastic deformation of different members?
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
It is possible that the piers may deform to absorb some of the thermal movement, however, there may other undesirable affects that could lead to failure before all thermal forces afre absorbed
hokie66 - to find the FCM's you remove a member, analyze the structure, see what happens; repeat the process for all tension members.
I've seen several examples of PTFE bearings locked up at the stainless steel/PTFE interface only to deform in shear the elastomer below. In some cases the elastomer tore away from the sliding surfaces.
All it takes is for some debris to mar the surface of the PTFE. Or anything introduced that can raise the coefficient of friction from 0.02 (which is nothing) to 0.2 which could mean a lock up for the normal force on the bearing.
Qshake
As they say, "if it moves, salute it; if not, paint it."
Qshake
http://
Steel supplied to DOTs for major structures is traceable back to the place it was melted into ingots. It is tracked every step of the way to the bridge. In the fab shops, each piece is marked to indicate its place in the bridge. The shop drawings provide the information to locate which sheet of steel, or structural shape, the piece came from.
The tracking numbers are called heat numbers. Each heat is tested for chemical composition and mechanical properties. When required, additional tests such as hardness, charpy V-notch impact, etc. are performed and supplied to the fab shops and often forwarded to the DOT (owner).
Most of this QA/QC process is directly or indirectly mandated by the FHWA because of Federal Funding. In addition, unless exceptions are granted, iron and steel products have to be made in America, start to finish. I hear there are two significant projects overseas, one being fabricated in China for the State of California. I do not know the "Buy American" status of that specific project.
Regarding the comment about bridge behavior with "frozen" bearings ...
In my area of the country, bridges are designed to withstand a seasonal temperature fluxuation of 120 degrees F. Using the coefficient of expansion of steel, this corresponds to a temperature strain of 0.000780, half up and half down. The problem can be considered as a prestress force analysis. If you preload the steel with a strain of 0.000390 and release it, what happens?
In a determinant structure, it expands or contracts by this strain. If it is indeterminant, multiply the strain by 29,000 ksi, and you get something near 11 ksi internal stress. The structure will seek a new equilibrium and much of this load will cause additional force in the supports. There will be some raising of the deck and some additional force in the piers. The biggest problem is quantifying the degree of restraint at the supports.
Qshake
At the time this bridge was built US Steel and Bethlehem were still the major players in the US.
When I worked on a U.S. Steel plant under construction in Minnesota in 1966, the main concern was grinding the "Bethlehem" off some steel from the local fabricator when he let it get by on change order fabrications.
Dick
The actual tracking of a particular heat of metal didn't gain momentum until Adm Hyman Rickhover required all materials used in the construction of Submarines be tracked. He came down hard on all of metal producers that supplied materials for the Navy. It was quite helpful as the metals industry went across the board. The biggest change was in welding consumables as you didn''t have to remember the color codes and wander why one batch performed better than another.
The Nashville Bridge Plant near by boyhood home always slipped some paint on the embossed name on the steel used in fabrication so it was quite visible when loaded on a rail car for shipment. At this plant it was TCI, the Tennessee Coal and Iron Co.
My brother has talked to one of the old fabricators that work in the Nashville Bridge Shop. They made components for steel bridges all over the country. The components they made were 99% hot riveted. All holes were drilled and reamed and if at all possible machine set using tools by Mesta. They only hole punching occurred during WWII for what he called light weight construction. All the connection holes were drilled and ream whether they were for bolts or rivets.
He commented that when the machine setters hit the rivets there was no problem with the rivet being tight. They only used American Steel.
Sidelight:
The Nashville Bridge site is being razed to build a modern DI pipe mill. If it hasn't been removed there is onsite a block of Zinc that is 6' wide x 8' deep x 110' long form the old galvanizing plant. Removing it is going to be chore as it contains about 2% lead.
Last time I heard, several years ago, out of the ten largest steel mills in the world, none were in the US.
Regardless, if you build a structure and it operates fine for 40 years and then collapses under minimal load, that's not the kind of problem you'd normally associate with substandard materials.
My guess, because if you're not guessing, you're not playing along:
The compromise was with a connection from the secondary truss to the top chord of the main truss on the South and East side. The connection was corroded or fatigued or both; it was bad and the top chord of the truss that was supposed to be braced by the secondary truss was now only being braced by the decking. Contractor comes along to replace the decking, knowing what all contractors and bridge engineers know, that you can remove the decking because the bracing is provided by the structure... The top chord on the east (at the south end) buckles, splitting the deck first at the middle of the lanes and then pulling the entire south end to the east. From there the bridge collapses south to north.
Like I said guessing...
Source: American Road and Transportation Builders Association
In view of extensive coverage following the Interstate 35-West steel bridge collapse in Minnesota, ARTBA released key highway and bridge statistics:
Of the 594,709 U.S. bridges, 152,945 (26 percent) are structurally deficient or functionally obsolete, according to 2006 Federal Highway Administration data. Of the 961,382 federal-aid road miles, 161,750 (17 percent) are reported to have conditions needing resurfacing or reconstruction.
Of Minnesota's 13,008 bridges, 1,586 (12.2 percent) are structurally deficient or functionally obsolete -- third-lowest in the nation, according to FHWA. Of Minnesota's 31,612 federal-aid road miles, 2,871 miles ( 9.1 percent) are reported to have conditions needing resurfacing or reconstruction.
According to the U.S. Department of Transportation's 2006 "Status of the Nation's Highways, Bridges, and Transit: Conditions & Performance" report: a) Structurally deficient means that significant load-carrying elements of the bridge are found to be in poor or worse condition due to deterioration and/or damage; or, the adequacy of the waterway opening provided by the bridge is determined to be extremely insufficient to the point of causing intolerable traffic interruptions. A deficient bridge, when left open to traffic, typically requires significant maintenance and repair to remain and service. And, b) Functionally obsolete bridges result from changes in traffic demand on the structure. For example, a bridge designed in the 1930s would have shoulder widths in conformance with the design standards of the 1930s. However, design standards may have changed since that time.
Not too technical, but another description of the terms being tossed around.
Dick
http://w
A source familiar with the investigation has told the Pioneer Press that investigators were looking at the possibility at least several plates, known as gussets, were too thin at half an inch. Just inside the piers lie four gussets labeled "U10." They're a half-inch thick, according to design records.
The video definiately shows that the failure occured near the south pier. The bottom chords near the north pier failed after the collapse, I think due to excessive rotation of the members during the fall. thereafter,the north approach collasped, I think due to excessive elongation of the top choars near the south pier. I also think, that the east and west side bottom chords near the north pier did not deform simultaneously, which may cause the entire span to rotate westward during fall. This is probably why the span was about 50' away from the south pier after the fall.
I truely believe that something went wrong near the south pier bearing.
Copied from ENR
"Engineers Swarm on US Bridges to Check for Flaws."
By Tom Ichniowski and Thomas F. Armistead, with Tom Sawyer, Jonathan Barnes, Bruce Buckley and Lucy Bodilly
"Meanwhile, in Minnesota, planners pushed ahead to have a replacement bridge constructed rapidly, although they quickly ran into conflicts over potential enhancements such as adding light rail and more lanes. The Minnesota Dept. of Transportation on Aug. 14 whipped out a preliminary design to solicit feedback. It features a 10-lane bridge with four shoulders, allowing room for expansion. The old bridge started as a six-lane crossing and later was expanded to eight by claiming most of the shoulders. The proposed alignment appears to match the old one."
Also adding that the wobbling experienced by the workers, that was increasing as the work (removal of concrete deck) proceeded, cannot be explained by the failure of some gusset plates, unless this failure occurred many days before the collapse. The wobbling should be caused by the buckling of a main element, that, till the collapse, was stopped and recovered by the intervention of some other structural restraint.
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
