Intrinsically Safe
Intrinsically Safe
Intrinsically Safe
I'm using a NEMA 4X enclosure that is being supplied intrinsically safe power for a Class 1 Div 2 application.  In the NEMA 4X enclosure, I will have several 3-position selector switches.
1.) For those selector switches, will I need to use hermetically sealed contact blocks or am I allowed to use standard contact blocks?
2.) If we are allowed to use standard contact blocks, which article & section of the NEC states that we can use them?
Any help would be appreciated!  Thanks!
RE: Intrinsically Safe
Article 504, Section 504.20. See also 504.10; the installation must be consistent withthe manufacturer's control drawing.
