Hole Pattern Along a Curved Path
Can someone direct me to how to create a hole pattern that is spaced a constant distant from a part's edge and the part's edge is a curved path? Thank you.
RE: Hole Pattern Along a Curved Path
If the part's edge IS a single curve then: offset the edge the distance you need, make the line construction, define the first center. Use the circular array command but you'll have to know how many centers you want and the degrees in between each center.
