API: offset sketch entites to current sketch from assy component
Hi
I am trying to write a (what I thought was easy) macro to help me save some much needed time winky smile  Basically I am editing a part in an assembly and have an active sketch open.  I want to select a component or face in the assembly and run the macro.   The macro will determine which part is selected and look for a specifically named sketch in the parts tree (fred)  once it finds fred, it should offset all of the entities contained within fred into the currently active sketch.
So far I have got the first bit sorted (determining the part, looking for and finding the sketch)  But i can't seem to grasp how to grab the entities within the sketch and offset them all from teh selected feature.
any help greatfully appreciated.
thanks
Rich.
code snippet.
selected item checked with
Set swComp = swSelMgr.GetSelectedObjectsComponent2(1)
then skip through to find with
Set swFeat = swComp.FirstFeature
While Not swFeat Is Nothing
 Debug.Print swFeat.Name
 If swFeat.Name = "fred" Then
 ''GetSketchEntities stuck here
 End If
Set swFeat = swFeat.GetNextFeature
RE: API: offset sketch entites to current sketch from assy component
sygenics,
The call you are looking for I believe is SketchManager.SketchUseEdge (I did not try using it in an assembly model, but it did work when I used it in a part model).  Anyway, after you find "fred" you then use the call Feature.Select2 (or ModelDocExtension.SelectByID2) to select the sketch after which you call the SketchUseEdge.
SA
SolidAir
thanks for the reply.  I just tried it but am getting 'object variable not set' error.  I assume its because the sketch manager is not pointing to the parent of the selected sketch?
I just tried :
Set swModel = swFeat.GetOwnerFeature
Set swSketchMgr = swModel.SketchManager
but no joy. any ideas?
thanks
Rich
sygenics,
Since I cannot look over your code, I have no idea why you are getting the error message; it can be caused by many things.  However, I did take a few minutes to explore your original question.  The (very rough) code below is what I came up with.  It is kind of crude (because I believe there may be a better way to do it) but it should get you going.  I tested the macro on SolidWorks 2007 SP 4.0 (I assume you are running SW2005 or earlier because SelectionMgr.GetSelectedObjectsComponent2 has been obsolete since SW2006).  I had an assembly open containing two parts.  On part was set to edit mode and I had created a sketch in it.  I clicked on a face of the other part (which contained a sketch named 'fred')to pre-select it and ran the code.
SA
CODE
Dim swApp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Dim swSkMgr As SldWorks.SketchManager
Dim swFeat As SldWorks.Feature
Dim swComp As SldWorks.Component2
Dim swSelMgr As SldWorks.SelectionMgr
Dim swAsmDoc As SldWorks.ModelDoc2
Dim retval As Boolean
Dim PartName As String
Dim AssyName As String
Sub main()
    Set swApp = Application.SldWorks
    Set swAsmDoc = swApp.ActiveDoc
    AssyName = swAsmDoc.GetTitle
    If InStr(1, AssyName, ".sldasm", vbTextCompare) Then
        AssyName = Replace(AssyName, ".sldasm", "", 1, -1, vbTextCompare)
    End If
    Set swSelMgr = swAsmDoc.SelectionManager
    PartName = swComp.Name2
    Set swDoc = swComp.GetModelDoc
    Set swSkMgr = swAsmDoc.SketchManager
    Set swFeat = swDoc.FirstFeature
    Do Until swFeat Is Nothing
            retval = swAsmDoc.Extension.SelectByID2("fred@" & PartName & "@" & AssyName, "SKETCH", 0, 0, 0, False, -1, Nothing, 0)
            swSkMgr.SketchUseEdge False
            Exit Do
        End If
    Loop
End Sub
Hi Solidair
It works like a charm, thanks! I just need to change it now so it iterates over a whole selection of parts rather than just one :)
Do you know how to fully resolve a part so that its tree is available? (not there in lightweight)
Thanks for your help, much apreciated
Rich
sygenics,
Although not immediately obvious in the API help, after a bit of research I came up with Component2.SetSuppression2
SA
thanks man!
I noticed that the macro doesn't work if you have selected a part in a sub assy rather than the current level assy.  The API is a bit confusing here on how to select parts in a sub. Any ideas?
Rich
sygenics,
It certainly gets more complicated.  What you have to do is parse the value returned by swComp.Name2 (again there is probably an easier way but, I do not know how without more study).  For example, if the sketch "fred" was three sub-assemblies deep, swComp.Name2 would return: Assem3-1/Assem2-1/Assem1-1/Part2-1.  To use it with SelectByID2 you would have to parse the value to: fred@Assem3-1@Assem4/Assem2-1@Assem3/Assem1-1@Assem2/Part2-1@Assem1.  If you look close, you can see that there is a pattern.  Once you figure the pattern out, you should be able to write a parsing routine.  If I come up with a better way to do it, I will let you know.
SA
thanks again, it makes sense.   I'll give it a go......
Rich
