flange¦s grade
flange¦s grade
Hi, I am doing a Rerating of a pressure vessel; my problem is that I don’t know the grade of a flange (Class 600).
Does anyone know how can I do to obtain this information (consider that I haven’t got documentation of this flange), perhaps some geometric characteristic of the flange?
Thank you and sorry about my English.
RE: flange¦s grade
Go to this site if its the latter. http://www.texasflange.com/Dimensioncutsheet.htm
RE: flange¦s grade
http://www.pacificflange.com/catalog.html
http://www.weldbend.com/tableofcontents.htm
RE: flange¦s grade
Mike
RE: flange¦s grade
thank you
RE: flange¦s grade
As stated above a 16.5 flange should have the Class, material, heat # , and manufacturer stamped of the periphery.
RE: flange¦s grade
Are you uprating the vessel? Will changing flange materials get you there? You may not necessarily need to match flange and nozzle materials.
If you do have a B16.5 flange, this should be marked on it as well.
If you are uprating, you will need to confirm the entire design, not just the flanges.
Mike
RE: flange¦s grade
Thank you.
RE: flange¦s grade
You might find anything in a customer spec however.
Mike
RE: flange¦s grade
GOOD LOOK
